ODSS Bolters return from
WINCHESTER
Virginia
September 21-23
Read the
HOT WASH!
17 members (breezy, 3B, 49.3600, BC59, 78buckshot, cmayna, 2 invisible),
681
robots. |
Key:
Admin,
Mod
Forums65
Topics123,421
Posts999,149
Members47,256
Most Online1,229 Jan 21st, 2020
Gearhead, Moderator for The Swap Meet and General Truck Talk
Ron,
The lack of proper tire pressure (22 psi you reported) directly relates to your mileage. To get this conversation back on the original topic, how about getting back with us on the difference you may (or may not) have experienced now that your tires are up to proper pressure levels?
Appreciate if you would keep the conversation on the original topic please and thanks!
Feel free to start a new post on your mileage topic (in the appropriate forum) if you want to continue that discussion.
Best Regards,
Dan
Dan
1951 Chevy 3 window 3100 (My Grandpa's hunting truck) 1966 Chevelle (Wife's Hot Rod) 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) Com Fac Maint Lead Tech Retired (1998-2021)
Finally time to get to work on my Grandpa's (now mine) truck!
OP
Just returned from a 25-mile circuit of country and in-town driving. It has seem to have improved the ride. Why it should improve the ride over serious bumps I don't know. The need to replace the shocks has diminished. I hope. Now its the strange part, I had what I called a wiggle waggle, similar to a duck shaking water off its tail. It was frequent on the highway home from town and it has gone away. Sidestreet's with tar stip fillers and raised portions are also diminished. Happy with the change for now.
WebOLD Check your toe-in,sway bar if you have it,axles paralell with each other. That is kinda hard to tell if axles are paralell .
Also, didn't we determine some time back that those tires are pretty old? Old tires lose their elasticity even if they aren't dry rotted. Belts could be separating inside, wheel weights could have fallen off, etc. Make sure all your lug nuts are tight. You don't want the wiggle wiggle to result in a tire flying off.
1939 Packard Standard Eight Coupe (The Phantom) 1950 Chevrolet 3100 (Ol' Roy) 1956 Cadillac Coupe de Ville (The Bismarck) 1956 Cadillac Sixty Special Fleetwood (The Godfather) 1966 Oldsmobile Toronado (The Purple Knif) 1966 Ford Mustang (Little Red) 1964 Ford Galaxie 500 coupe 1979 Ford F-100 1976 Ford F-150 (Big Red) 1995 Ford F-150 (Newt)
Proper inflation will stiffen the sidewalls and stop the wiggles. When they are underinflated you get side to side motion as the sidewalls roll around.
You will also get additional spring effect from underinflated tires that is not damped by your shocks. Having them be properly stiff will help on bigger bumps lile you mentioned.
From the Rocky Mountains?Check in with the RM Bolters!HiPo Forum Moderator1958 Apache, long bed Fleetside, V8 w/SM420 Driveable but the rear axle needs work. 1959 Apache, long bed Fleetside that has been in the family for 25 years but in desperate need of love.
OP
