Sir, Do you happen to have an harmonic balancer & key for 'a 56 stovebolt 235 6 cylinder engine? Why? My engine has a wobble when at idle & levels out at higher rpms. Some more knowledgeable Old Dominion Stovebolt Society (ODSS) gents advised there is an issue with the balancer/key & won't know for sure until it is taken apart. The ODSS Wrenchfest last month enlightened me to the issue cause I went & met in person good shade tree mechanics. Please advise. Thanks Tom. V/r, Nick
Nick - I can help you because I have one from a 261 but not the woodruff key that is a standard hardware store item.
PM me. Need to send today or will need to wait 2-3 weeks from now when I return to the land of milk and honey, up here north of the Notches.
In regards to your association and associates at/of the ODSS? I can’t help you there. There are highly qualified therapists that may be able to assist you. You are on your own with that issue but do post updates as you travel the ODSS therapy path. The rest of us can benefit from your experience.
Tom I realize you are leaving today so put this in your que when convenient. Late 235 oil bath air cleaner, roch carb. It has the wider throat. Actually looking for the cap for future ventilation project.
