ODSS Bolters return from
WINCHESTER
Virginia
September 21-23
Read the
HOT WASH!
Forums65
Topics123,394
Posts998,884
Members47,253
Most Online1,229 Jan 21st, 2020
The fix for sloppy cast iron pistons was a spring steel expander device that was installed in the wrist pin area with a special set of pliers. They're still available from some of the vintage parts suppliers on Ebay. They're specific for different engines, depending on the bore size. www.ebay.com/itm/174391484763? [ ebay.com] Jerry
52 Carl That is a good feeling to get one adjusted up like that,biggest trouble there is having round journals to work with !
