ODSS Bolters return from
WINCHESTER
Virginia
September 21-23
Read the
HOT WASH!
Forums65
Topics123,394
Posts998,886
Members47,253
Most Online1,229 Jan 21st, 2020
OP
1959 Chevrolet Viking 40
Rich Winter Janesville, MN
I was approached this last fall (2020) and asked if I might be interested in this truck. It was located about 5 miles from my place. I had seen it in the past and it always appeared to be in fairly decent shape so I went to check it out. It was in a shed and had not been used since 2014, as their farming operation outgrew it. At some point the fellow's dad had replaced the original 6 cylinder engine with a 283 V8. The cab is in remarkably good shape for its age--a couple of small rust areas, but I've seen much worse on trucks of this age. It has 19.5" tires with the 5 and 10 lug bolt pattern. We agreed on a price and my wife and I towed it home with our pickup. There were no brakes on it so I rode the hand brake as necessary. After getting it home it didn't take too much to get it running. Mostly a matter of cleaning the points, freeing up the linkage for the manual choke which had rusted, and putting some fresh gas in the tank. So far that's about all I've done with it. It needs a new water pump, plus getting the brakes fixed, and a few other things. These will be addressed when the weather improves next spring, along with a good clean up.
Workshop Owner
Nice Viking Rich, yours is in way better shape than mine. Looks like yours has a dump bed as well.
Thanks for posting.
J Lucas 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWB 1959 Chevy Apache 31 Fleetside 1959 Chevy Apache 32 Fleetside 1969 Chevy C-50 Grain Truck My Flicker Photos! [flickr.com]
OP
Yes, it does have the dump bed. Have not tried that yet, as the cable which engages the PTO is also rusted up and not moving--something else I need to take care of when the weather warms up!
OP
Got the cable freed up. The hoist works great! Fuel pump, water pump and exhaust system have all been replaced, plus extensive work done on the brakes. Currently have the generator off getting rebuilt. I also re-did the tail lights and rear turn signals so everything is now working as it should back there.
In the Stovebolt Gallery [ stovebolt.com] More pictures here [ photos.app.goo.gl] 1951 GMC 9430 1 ton dually—-Shiny! 1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny 1972 Chevrolet C20- Rusty- the puzzle box lid for the C10. 1950 Chevrolet 1300- in progress to shiny. 1962 AMC Rambler American- my wife’s Parts trucks- 1951 GMC 9300 1951-GMC 9430 1951- Chevrolet 1300
OP
Had some more brake work done. Also had the transmission replaced with one from a donor truck. Some of this was discussed in the Big Bolts forum. Also had the seats reupholstered, but they won't get installed till next spring.
OP
I added a couple photos to the original post. Got the new seat installed. also removed the grain sides from the bed and replaced them with 12" sideboards.
Crusty Old Sarge
Rich, After loading the side boards that came with my truck I fully intend to do as you have and build my own.
Craig
"Living life in the SLOW lane"
Come, Bleed or Blister something has got to give!!! '59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) '58 Viking 4400, 235, 4 Speed (Thor)
OP
I hear ya! Those things are not light! I had to get help to carry them inside. I did keep them though, in case I or someone else ever wants to convert it back to a grain hauler.
