I’ve got the choke cable hooked up but the throttle cable has me scratching my head. The attached show the clamp for the cable housing but I don’t see anyplace to attach the cable. Any ideas how it attaches would be appreciated.
1954 Chevy 3100 One problem solved doesn’t seem to shorten the list Montgomery, AL In Project Journals
In your photo do you see where the elbo of your choke cable almost touches the rusty metal part? That is the clamp where the throttle cable goes in from the top.
I'll rustle up a picture.
1939 Packard Standard Eight Coupe (The Phantom) 1950 Chevrolet 3100 (Ol' Roy) 1956 Cadillac Coupe de Ville (The Bismarck) 1956 Cadillac Sixty Special Fleetwood (The Godfather) 1966 Oldsmobile Toronado (The Purple Knif) 1966 Ford Mustang (Little Red) 1964 Ford Galaxie 500 coupe 1979 Ford F-100 1976 Ford F-150 (Big Red) 1995 Ford F-150 (Newt)
A couple of the pictures were taken during installation so the sleeves were not cut to length.
When you hook up the throttle cable, leave about 1/8" of play between the cable nut and the throttle rod when the throttle cable is pushed all the way in and the throttle rod is at rest,
You can buy those at a bicycle shop. The one in my picture came from there. They're used on brake cables and shift cables etc. Or Dorman makes those and they're usually available at any auto parts store. I think they're called barrel nuts.
Originally Posted by Phak1
The throttle cable takes the place of the cotter pin. Here is directions from the Assembly Manual.
Notice that Phil has "circled" that "gap" below the lever rod, if you don't have a sufficient gap the throttle won't drop back against the idle stop screw and you'll have a fast idle. Don't ask how i know this....
Ron - - Dusty53 "you can't dance with the Devil and then wonder why you're still in Hell" " They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel"
You must have skimmed over my previous post. They're called cable stops. You can get them at bicycle repair shops. They're used to secure brake lines and gear shift cables.
Any auto parts store will have them sold under the Dorman brand.
