BUSY BOLTERS
Are you one?
The Shop Area
Forums65
Topics123,442
Posts999,498
Members47,277
Most Online1,229 Jan 21st, 2020
OP
Having just celebrated 50 years with my original 1946 and we were planning to attend the Southern Stovebolters meet in Townsend, TN my 216 has apparently puked! It was lacked power and I perceived the sound from the engine was a ping and the timing and points might need some attention. After spending yesterday in my garage, the noise was a slight popping gurgle from the carburator that would not diminish with timing adjustment. Vacuum advance working, vacuum readings bouncing from 14-16 lbs., checked plugs and wires, and found #2 and #3 missing. Compression test was good on the other four but #2 and #3 was zero with just a little bounce while cranking. I had recently done a valve lash adjustment and thought that maybe that was the cause with a possible valves remaining open. The valves all appeared to be operational, so I backed off the adjustments, sprayed some PB Blaster and Marvel Mystery oil on the valve shafts to hopefully free up a possible stuck valves. I even ran about a half pint of Marvel through the carburetor at higher rpm hoping to free up stuck valves, creating quite the smoke cloud for the neighbors.
I then introduced some oil into the offending cylinders for a wet compression test to verify that the rings are good and the offender is probably a blown head gasket. I had previously noted an offending trail of antifreeze going into the garage after topping off the radiator and just wrote that off to overflow.
My next dilemma will be taking the manifolds and head off when I am not suppose to lift more than 10 pounds due to service-connected back issues, it will be time to rent a cherry picker. Looks like the '46 will miss it's birthday party at Townsend, but Linda and I will still meet our Bolter friends.
You can probably buy a cherry picker on Craigslist or FB Marketplace for $100 or less. That's what I did. There were tons around here. People buy them to use on a one-time repair and sell them when they're done.
A blown headgasket is better than a rod through the block!
1939 Packard Standard Eight Coupe (The Phantom) 1950 Chevrolet 3100 (Ol' Roy) 1956 Cadillac Coupe de Ville (The Bismarck) 1956 Cadillac Sixty Special Fleetwood (The Godfather) 1966 Oldsmobile Toronado (The Purple Knif) 1966 Ford Mustang (Little Red) 1964 Ford Galaxie 500 coupe 1979 Ford F-100 1976 Ford F-150 (Big Red) 1995 Ford F-150 (Newt)
Do you need some help on that project? I'm pretty close, relatively speaking, Just a bit north of Huntsville, and my engine lift knows its way on and off a trailer. It's followed me all over the country scavenging up stovebolt boat anchors! I've also got the equipment to do a valve job if necessary. Drop me a PM if you like. Jerry
Keep us posted on your situation. Iām not too far away and have pieces/ parts, and head for 216 and a spare 216 in my garage that was pulled from a truck and supposedly ā ran when pulled ā . I think the date is 1947, but I would have to check
I invest my money in precious metals, mostly rust!
OP
OP
Thanks, still don't have Xray vision, I will find out when the head gets pulled, hope it is head gasket, probably do the valve job.
