Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
13 members (Gdads51, Donf, baldeagle, glennj3, DES57, 32vsnake), 153 guests, and 3 robots.
The Zone
Forums65
Topics123,445
Posts999,547
Members47,279
Most Online1,229
Jan 21st, 2020
#1501904 Tue May 23 2023 10:48 PM
EdPruss Offline OP
Has anyone found a tool for forming new ends on vent cables? I need to shorten both on my ‘55. I am sure factory had one.
Ed
EdPruss #1501914 Wed May 24 2023 12:41 AM
I am going to guess that the main cable is very stiff (hardened or spring steel) and will require annealing in order to make that bend.
That requires heat until light red then allow it to cool naturally. Then you can readily bend it to that shape.
My concern would be that this annealing process may soften the adjacent straight section of cable, rendering it subject to bending under stress of pushing the lever.
You may be able to restore the stiffness of the cable by heating to red hot and quenching it in oil.
EdPruss #1502021 Wed May 24 2023 11:35 PM
EdPruss Offline OP
Got it made. Started circle with needle nose pliers, when full circle finished , ground off first leg, grabbed from outside and completed full circles, practiced on cut off pieces.
Ed
EdPruss #1502022 Thu May 25 2023 12:13 AM
Good deal! You may have saved yourself a perfectly good cable from total destruction by not attempting my half-baked idea. smile
EdPruss #1502054 Thu May 25 2023 10:49 AM
EdPruss Offline OP
52Carl,
Heating it like you suggested was on my list to try, since I had extra cable to try.
Ed
EdPruss #1502436 Sat May 27 2023 05:14 PM
Ed Pruss At home 60 years ago we had a set of German made (with round tapered jaws ) that would make those right up.I still use that same pair today. Don't anneal but maybe I should,have to experiment a little on that.
EdPruss #1502454 Sat May 27 2023 07:24 PM
EdPruss Offline OP
fixite7,
Do you have a picture of that tool?
Thanks, Ed
EdPruss #1502646 Sun May 28 2023 10:57 PM
EdPruss Those pliers are like a short pair of needle nose (no cutter) with round tapered jaws. Up next to the hinge jaws are square perfect for a 90 degree bend,Krauter brand on the pivot point. Great for electrical eyelets on copper,music wire,or just any wire.
