BUSY BOLTERS
Are you one?
The Shop Area
10 members (Joe Alan, baldeagle, BC59, 3 invisible),
71
robots. |
Key:
Admin,
Mod
Forums65
Topics123,445
Posts999,559
Members47,279
Most Online1,229 Jan 21st, 2020
OP
Anyone have “hands on” experience with how one of these runs on a 216/235?
(This is purely curiosity. I don’t own one or have a plan to own one.)
I have some vague memory of reading that the design was intended to equalize the runner length and eliminate 90 degree turns. I can no longer locate the source of that information.
Both of those goals make some theoretical sense.
Eye candy- - - -the real problem with 90 degree turns is in the cylinder head, with no way to improve the situation, so anything that's done manifold-wise is the product of a collaboration between P.T. Barnum, Rube Goldberg, and W.C. Fields! Jerry
Any down-draft carburetor requires mixture to turn 90° below the throttle disc (toward left or right in the plenum), and then again 90° inward to align the manifold runner with the intake port. No angles: side-draft only, like the Corvette (although the alignment is not perfect).
Equal length? I'm not sure that's best, because the two pairs of cylinders drawing from the front & rear intake ports are strongly irregular because of the firing order: 1 5 3 6 2 4. Cylinder 1 & 2 and 5 & 6 intake strokes are separated by 240°-480°-240°. Only cylinders 3 & 4 have exactly equal intake strokes: 360°-360°-360°.
