Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
18 members (53 green 1- ton, Gdads51, David Bush, 3B, Dusty53, 1 invisible), 675 guests, and 3 robots.
The Zone
Forums65
Topics123,436
Posts999,447
Members47,277
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1502102 Thu May 25 2023 04:49 PM
homer52 Offline OP
I am about to start on my 41 chevy coe. My plan is to put it on a 2001 chevy 3500 cutaway van chassis, it has an 8.1 engine. The floor pans have some issues with rust but I think I may have to replace the entire floor to accommodate the engine. If it comes to this happening what kind of bracing would I have to put in place to insure things fit when I'm done? Dave
Pictures [s300.photobucket.com]
1941 Chevy
1941 GMC resting peacefully
1946/1947 Chevy
1945 GMC panel truck in line for restoration
1941 Plymouth in the restoration process
1941 Chevy COE in line for restoration
homer52 #1502111 Thu May 25 2023 05:57 PM
Dave, what you might consider is building a floor framework out of angle iron (maybe 1x1x1/8) that fits the engine /trans configuration and then cut out the floor panels and fabricate new to fit the framework. The angle framework should hold the cab in the right shape.
Are you planning on keeping the original finish with the lettering on the doors? I think that would be a cool rig. Although it is kind of faded out, it would be cool to have that old lettering on the doors (maybe reproduced, if nothing else.)
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
homer52 #1502182 Fri May 26 2023 02:16 AM
homer52 Offline OP
Thanks Kevin, I may try the angle framework. I have to mock up the 2 on a temp basis to see if I can even leave the engine in the original location.
I have thought about the lettering but not decided as of yet. My first thought and most likely will be to paint it exactly the same as my 41 and 47 pickups.
1941 Chevy
1946/1947 Chevy
homer52 #1502207 Fri May 26 2023 11:47 AM
Where are the pictures? When I click on the signature link it goes to photobucket with a message that says "Sorry, nothing here."
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1956 Cadillac Sixty Special Fleetwood (The Godfather)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
homer52 #1502236 Fri May 26 2023 03:47 PM
homer52 Offline OP
I don't know, they used to be there.
1941 Chevy
1946/1947 Chevy
homer52 #1502251 Fri May 26 2023 04:50 PM
Same here, no pictures. I have come to love COE and would like to follow along on your journey.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery [stovebolt.com]
2017 Buick Encore
See more pix [photos.google.com]
homer52 #1502269 Fri May 26 2023 06:31 PM
I've got a couple pics of Dave's COE. With his permission I can post them.
homer52 #1502427 Sat May 27 2023 04:48 PM
homer52 Offline OP
Go right ahead.
1941 Chevy
1946/1947 Chevy
homer52 #1502430 Sat May 27 2023 05:01 PM
Pics of Dave's 41 COE thumbs_up
DOOR LETTERING
homer52 #1502439 Sat May 27 2023 05:28 PM
homer52 Offline OP
I hope this works,I attached 2 photos. It did! In the second photo you can see the alterations that were made to put that HUGE axle under the 1 1/2 ton truck. The first photo has the cab ready for my friend to liftoff with his tractor.
1941 Chevy
1946/1947 Chevy
Page 1 of 2 1 2
