Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
12 members (2-Ton, Hotrod Lincoln, Gdads51, Johnny N, 2 invisible), 703 guests, and 3 robots.
The Zone
Forums65
Topics123,437
Posts999,465
Members47,277
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1501981 Wed May 24 2023 06:37 PM
I remember that there were 2 small sheet metal filler panels that go under the hood to close off a couple of open areas. I have reproduction panels, but can't remember where they go. Anybody have pics they could post?
Mike Burns
1940 Chev 1/2 ton
1953 Chev 1/2 ton
1953 Ford Victoria
1950 Studebaker Starlight Coupe
Here's a couple of pics. Hard to tell, but I think the L-shaped one goes on the driver's side.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
I ran across the original L-shaped filler piece today. It still had a screw in it that indicated it was installed on the driver's side. I believe the lower L part was to cover the parking brake bracket that mounts there.
Here's a couple more pics to assist you....
Drivers side filler
Passenger side filler
Ron - - Dusty53
"you can't dance with the Devil and then wonder why you're still in Hell"
" They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel"
1954 Chevy 3604
Ron, not criticizing, but the originals were painted black. You can see the remnants of the black paint on what's left of my original filler. I've painted mine body color too. wink
ORIGINAL FIREWALL FILLER - OR WHAT'S LEFT OF IT
Well darned, Kevin! I missed that one. Oh well, they'll stay green. That anti-sqeak was a bit of a challenge to install with staples.
Ron - - Dusty53
1954 Chevy 3604
Well done on the partial cuts on the sharp corners. I saw a very original truck with enough of the seals left on them to indicate that what you did is correct.
It always bugs me to see one of these trucks which someone paid someone else a fortune to build their truck, but leave those panels off.
I like the look. I hope I can make mine turn out as well. thumbs_up
What supplier can that "anti-squeak" be found as you show? Just looking for the cheap.
54 Chevy 3100 Deluxe 3 speed on column. Keeping original as possible but changed to 12 volt system.
JB Weld..."I put that sh*t on everything"
I got the fender mounting isolation set from Jim Carter. They say it includes the stuff for the filler plates as well as the inner fenders. Their PN FP119.
Although I just got a catalog from Restoration Specialties www.restorationspecialties.com [restorationspecialties.com] and it has hundreds of bits like that. Haven't found that in their catalog, but you could give them a call. 814-467-9842 They're in PA.
Page 1 of 2 1 2
