ODSS Bolters return from
WINCHESTER
Virginia
September 21-23
Read the
HOT WASH!
Forums65
Topics123,394
Posts998,891
Members47,253
Most Online1,229 Jan 21st, 2020
OP
AD Addict
I’ve been wanting to install a PCV system on my ‘59 235 for several years now. Couple of years back, I purchased a NOS PCV riser to replace the down draft tube. I need the PCV valve that screws into that riser and is listed as GM part #1544935. I can’t find a cross reference to that number. I did a search on PCV system on this site but seem to go down a rabbit hole. I found a valve that physically would work on ebay, but want to confirm it will work before I spend 35 dollars on something that may or may not work. Here is a link to the valve I’m looking at. https://www.ebay.com/itm/1447013202...r=&widget_ver=artemis&media=COPY
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100 Project JournalsStovebolt Gallery Forum‘59 235 w/hydraulic lifters “Three on the Tree” & 4:11 torque tube Updated to: 12v w/alternator, HEI & PCV
Insomniac
Gord ---- 1954 1/2 ton 235 4 speed
OP
AD Addict
Gord, I found both of those threads, in fact I posted info to one, but I can’t find the cross reference to the GM part #1144935.
I do agree that the eBay item I posted does look correct, but was hoping for a direct cross reference or somebody that actually installed one to say “you need this AC part number…” and it works! Thanks for your suggestions!
Hopefully I’ll get some more input!
Gearhead, Moderator for The Swap Meet and General Truck Talk
Phil, Take a look at this previous thread on the subject. Member "bouymaker" provided some detailed original and replacement GM part numbers along with the corresponding "AC Catalog" information in his reply post. I just did a quick check on eBay and saw several NOS GM# 5647228 items being offered for sale. Hope this helps out. Dan
Dan
1951 Chevy 3 window 3100 (My Grandpa's hunting truck) 1966 Chevelle (Wife's Hot Rod) 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) Com Fac Maint Lead Tech Retired (1998-2021)
Finally time to get to work on my Grandpa's (now mine) truck!
OP
AD Addict
Perfect! That is the confirmation I was hoping for. I went ahead and ordered it.
Thanks Dan and Gord for your help!
Insomniac
GM parts wiki says that 1544935 was replaced by 5647228.
That's what the eBay listing says the part for sale is.
Best if it looks like & fits like the original, but that does not determine how it works. There are only 3 important data points: 1. high vacuum orifice (cruising, light throttle) 2. low vacuum orifice (big throttle opening) 3. internal spring which sees engine vacuum and moves the internal restrictor cone to select 1. or 2.
If the engine is stock, a PCV from a very similar engine (size, power, tune) may work well. If the engine has a big cam, the stock PCV will not work as intended.
I purchased a PCV valve sold as P/N 5647228, CV-469C a while back. It came in a silver and orange foil package. The valve was black with PAT. 32633699 stamped on it. Both ends were a correct fit, the air flow direction is correct and it has a similar spring-loaded plunger as the original AC 1544935 valve I have. The main difference is the 1544935 has a hole through the center of the cone shaped spring-loaded plunger. Air will moves in both directions; the volume of air will be varied by the movement of the cone. Perhaps PCV technology improved the design of the replacement valve.
1954 Chevy 1300 engine 235 (1959) 1955 (first series) Chevy 3100 engine 261 (1957) 1927 (other brand) Model T- engine 327 (1968)
Does anyone know what kinds of threads the 5647228 has? Looks like maybe pipe thread on one end and flare on the other?
OP
AD Addict
It’s 1/4” NPT pipe on the end that screws into the PCV riser (I have the riser) and the other I suspect an inverted flare fitting.
