Major event in Virginia
Look Look Look
ODSS Bolters
head to
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the details.
Searching the Site
13 members (kahoys, Adamg, 52Carl, 2-Ton, D B Cooper, 1 invisible), 141 guests, and 3 robots.
The Zone
Forums65
Topics123,370
Posts998,595
Members47,287
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1501514 Sat May 20 2023 07:22 PM
Got my truck cranked. Checked all fluids and they were good and fresh. But motor has a tick. Where should I start? Also moved the truck under a shed and went in to reverse fine then when I put it in 1st it wouldn’t come back out.
Anthony Riley #1501518 Sat May 20 2023 08:18 PM
Couldn't say about the transmission without looking at it, but possibly linkage out of adjustment or hanging up somehow. The ticking might be a valve out of adjustment or a faulty (collapsing or sticking) hydraulic valve lifter. If you get a long screwdriver and put the handle end up next to the bone by your ear opening and the tip at various places along the length of the valve cover you can often tell where the ticking gets worse and that will let you know which valve or lifter might be having the problem. Alternatively it could be a time bomb. An old style time bomb...I think most of the new ones use digital timers so you hear nothing but BANG at the end. Please let us know if it explodes.
Jon
1952 1/2 ton with 1959 235
T5 with 3.07 rear end
Anthony Riley #1501531 Sat May 20 2023 10:00 PM
What year truck and what engine?
If it has hydraulic lifters it could be that one of them has leaked down While it was sitting around. How long did you let it run after you started it?
Could even be an exhaust leak.
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1956 Cadillac Sixty Special Fleetwood (The Godfather)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
Otto Skorzeny #1501536 Sat May 20 2023 10:45 PM
It ran for a while. I tried to post a video but it didn’t post on the thread.
Otto Skorzeny #1501537 Sat May 20 2023 10:46 PM
60 with a 235
Anthony Riley #1501539 Sun May 21 2023 12:09 AM
AD Addict
If it’s a three speed, I Agree with Jon, the shift linkage is more than likely out of adjustment. I’ve linked the section from the Shop Manual that covers the adjustment. Here’s the link.
http://chevy.oldcarmanualproject.com/shop/1954truck/54ctsm0702.html
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
Updated to: 12v w/alternator, HEI & PCV
Anthony Riley #1501540 Sun May 21 2023 12:13 AM
AD Addict
Stovebolt rules prevent you from uploading a video. If it’s posted on hosting site or YouTube, you can link it.
Phil
1952 Chevrolet 3100
Project Journals
Phak1 #1501550 Sun May 21 2023 02:36 AM
Anthony Riley #1501556 Sun May 21 2023 03:15 AM
That sounds like it is relating to a valve, a valve lifter...something in the valve train, Anthony. Otherwise the engine doesn't sound too bad. If you get it started again you can also remove the valve cover (you can remove it before you start it) and then you can feel the 12 pushrods to see where the ticking might be. If it is a sticking or collapsed lifter you will feel it in the pushrod...the rod will feel loose and you should be able to "feel" the ticking. Or you can use a long screwdriver as I mentioned before as a sort of stethoscope. Thanks for posting the video!
Jon
Anthony Riley #1501601 Sun May 21 2023 02:58 PM
Insomniac
My truck sounded like that. Found one plug was sooty; that cyl had a bent push rod. Also, some of the other valves were way out of adjustment.
Gord
1954 1/2 ton 235 4 speed
Page 1 of 2 1 2
