Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
13 members (Jack Ryan, Hotrod Lincoln, Curtis Jr, 3B, David Bush, 3 invisible), 671 guests, and 3 robots.
The Zone
Forums65
Topics123,436
Posts999,447
Members47,277
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1501185 Wed May 17 2023 11:24 PM
Keeping ole Blackie drivable as the first
goal while fixing things, I have removed the homemade
trailer hitch and bumper and now am
modifying the old generic bumper into
a ‘54 style, more or less. It will be painted. Having the license plate in the center the aim. Simplify the taillight array will be next.
Well, and rebuild the bed!
1954 Chevy 3100
1963 Chevy half ton stepside short box 230
1954 GMC 3 ton 302
And several more Chevy camper and work trucks 1979 1987 1996
1931 Packard car, 327 i 8 auto
Charley
Steelonsteel #1501189 Wed May 17 2023 11:46 PM
By the way, that flat spot on the bumper will be for a license plate light, not a trailer ball!
1954 Chevy 3100
1954 GMC 3 ton 302
Charley
Steelonsteel #1501198 Thu May 18 2023 01:10 AM
Yep, looks pretty original to me.
Ron - - Dusty53
"you can't dance with the Devil and then wonder why you're still in Hell"
" They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel"
1954 Chevy 3604
Steelonsteel #1501212 Thu May 18 2023 02:54 AM
Thanks, Dusty, I used your picture for reference !😏
And I believe this truck was Sea Green originally.
1954 Chevy 3100
1954 GMC 3 ton 302
Charley
Steelonsteel #1501223 Thu May 18 2023 08:46 AM
On my 54 3100 I installed a hitch with a flat plate welded on the size of my license plate. I can pull that out and install another hitch bar to tow with. I stick the license plate and adapter in the cab when I need to tow. BTW once in 13 years.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery [stovebolt.com]
2017 Buick Encore
See more pix [photos.google.com]
Steelonsteel #1501229 Thu May 18 2023 11:39 AM
Well that's an honor ! Hey, just so you know, I purchased the License Bracket / Lamp assembly from LMC, 36-4403 , $30 . Worked perfectly . Oh, and a quick check of the paint codes for 1954 ( Check under paint in the Tech Tips ) lists two "greens" for 1954. Juniper Green and Ocean Green. Mine is a close match to the Ocean Green. I've seen several at meets that were a shade or two lighter.
Ron - - Dusty53
1954 Chevy 3604
WE b OLD #1501254 Thu May 18 2023 02:08 PM
That sounds like a good hitch . A receiver hitch , I assume.
1954 Chevy 3100
1954 GMC 3 ton 302
Charley
Steelonsteel #1502623 Sun May 28 2023 09:27 PM
I had to cut all the bolts holding the bumper and supporting frame to get mine out.. it was broke in a couple places and welded over.. I'm going to go with a painted bumper on mine also..
I got a license plate bracket from classic parts that includes a light that fits where that cut out in the bumper goes... I'll post a picture when I get home tonight.
1954 Chevy 3100
One problem solved doesn’t seem to shorten the list
Montgomery, AL
In Project Journals
T-Doug #1503425 Sat Jun 03 2023 02:26 PM
Ok, Doug, I have ordered my license plate bracket. Also a seat upholstery kit, from Classic Parts.
I’ll get a picture when its in.
1954 Chevy 3100
1954 GMC 3 ton 302
Charley
Steelonsteel #1507985 Wed Jul 05 2023 07:35 PM
Well, the bumper tuned out ok, and license plate bracket is in, though no plate on it yet.
I think I read that the turn signals can be wired directly to the taillights and use the brake light bulb filament.
I’d like to take off the extra taillights. Will research the wiring details.
I have begun the repair of one box side and the bed. I’m making the boards from local mill rough sawn Douglas Fir.
While working in the empty bed space I spotted a long hidden Hide A Key box in the cross member above the
spare tire area. Very original looking ignition key, fits the ignition, which leads me to believe the ignition switch is actually original.
I think it is wired wrong so that Off is all the way to the left. Maybe supposed to be left:Acc. , middle:Off , Right:On .
I consider the key another treasure of this sentimental truck.🤗 I’ll post a picture.
I also am puzzling over a piece that was under the seat, a bracket, pictured, that has the keyhole-ish shaped hole.
Wonder where this goes ? Then, another thing, a metal tag in the seat back springs, with a number. S G 3693890.
Wonder if this relates to the year model of the truck?
The box patch metal is 1/16 sheet steel , but for one piece in the center, I am trying some steel from an old
crosscut saw, 1/16 inch. I wonder if anyone has tried using this stuff and welding it, and will it cause problems, being
quite hard, maybe spring steel? It was hard to cut and drill.
So I think I will post in the Interiors Forum about the seat covers.
So, I’ll get a picture up when the bed is done.
1954 Chevy 3100
1954 GMC 3 ton 302
Charley
Page 1 of 2 1 2
Moderated by  John Milliman, Phak1
