Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
12 members (Forty9, Jack Ryan, Gdads51, Donf, Hotrod Lincoln, 53 green 1- ton, 1 invisible), 673 guests, and 3 robots.
The Zone
Forums65
Topics123,437
Posts999,457
Members47,277
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1501115 Wed May 17 2023 11:44 AM
Morning all,
I have found that my door to rocker gap grows at the front of the rocker. For some reason the front 4 inches to rocker drops. Only thing I can think of is to weld onto the bottom of the door to close this gap. It is an extra 1/4 inch at its worst.
1966 C-10 Step Side
A Project Journal
AD Addict
Is the bottom of the door straight. Throw a straightedge on there and see what you got.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
Updated to: 12v w/alternator, HEI & PCV
Yes door is straight. Its the rocker that I messed up on unknowingly.
1966 C-10 Step Side
A Project Journal
Did you install the step with rocker or just the rocker?
I sure wouldn't apply anything to a straight door just to get the gaps to look good. Fix the rocker, or call it a day and move on.
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1956 Cadillac Sixty Special Fleetwood (The Godfather)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
AD Addict
Originally Posted by Ferris Bueller
Morning all,
My concern would be that the door weatherstripping would not seal properly in that area.
Phil
1952 Chevrolet 3100
Project Journals
No chance at fixing the rocker. It was installed with the step. I noticed it dipped down at the front too late.
If I add material to the door it should not be noticeable unless you wanted to put that door on something else.
I will take a pic tomorrow.
1966 C-10 Step Side
A Project Journal
Live with the mistake. Nobody but you will ever notice it.
1979 Ford F-100
RLB Offline
Sounds like good advice.
1966 C-10 Short Stepside
HiPo
Step-by-step ~ and on-going resto build
in the Project Journals
AD Addict
If you do extend the lip of the door, you may be able to shim the weatherstripping with foam tape to get it to seal.
Phil
1952 Chevrolet 3100
Project Journals
Page 1 of 2 1 2
