Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
16 members (GMCJammer51, 32vsnake, Donf, Gdads51, baldeagle, 68ironhead, 1 invisible), 128 guests, and 3 robots.
The Zone
Forums65
Topics123,445
Posts999,547
Members47,279
Most Online1,229
Jan 21st, 2020
Page 2 of 9 1 2 3 4 5 6 7 8 9
AH! Now I understand. You could surely lift the rebuilt engine that way, but you'd mess up the nice paint job on it. wink
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Unrepentant VW Lover
I'm thinking an axle saver run through there ...
"If there are no dogs in Heaven, then when I die I want to go where they went."
Will Rogers
1927 Chevrolet Capitol 1-Ton Express -- A work in progress
In Project Journals
1949 Chevrolet 3804
In Gallery Forum
1973 IH 1310 Dump
2014 Ford E-350 4x4 (Quigley)
In Daily Driver Gallery
I don't know if it is safe to hoist the engine using the gap in between cylinders 2 and 4 as the lifting point. Keep in mind that these four bangers weigh around 600 pounds.
Oh, something that is VERY important. The 1/2" head bolts DO NOT have 13 threads per inch. They have 12!
BTW, no rubber on the engine or transmission mounts.
If it were me, I'd put the engine on a stand, take off the oil pan, and do an inspection before dropping the engine into the truck. Here's why I would do this:
1. On Justin (my '28 Canopy Express), the previous owner assembled the engine after the block got done at the machinist shop. ALL the bearing caps were just finger tight! Luckily, they had cotter pins on the nuts, but imagine what would've happened if the pins were not there (shudder). This discovery let me to adjusting the bearing caps (removing or adding shims) to get the proper clearance around the crankshaft and tightening the bearing caps before putting the cotter pins in.
2. Having the oil pan off is a great opportunity to make sure that all the oil reservoirs that feed the cam and main bearings are clean and not full of sludge. Again, Justin's reservoirs were full of crud, so I don't have a lot of respect for the machine shop that worked on the block or the mechanical ability of the previous owner.
3. A new set of oil pan gaskets (either store bought or homemade) will help in preventing oil leakage. Getting the gaskets to stay in place around the front and rear main bearing caps is challenging. Here's what I do to make it work: https://vccachat.org/ubbthreads.php/topics/394210/re-resurrecting-a-28-4-banger.html#Post394210
4. Make sure the little wedge-shaped cover plates are in place to cover the gap between the flywheel cover and the block. For more info, read this part of my engine rebuild adventure from 2017: https://vccachat.org/ubbthreads.php/topics/400512/re-resurrecting-a-28-4-banger.html#Post400512
5. Check that the oil troughs in the oil pan are positioned properly so that the tangs on the rod caps actually dip into the troughs to create the oil mist that is necessary for all the internal oiling of the engine. Here's the procedure I followed for Lurch's engine: https://vccachat.org/ubbthreads.php/topics/394209/re-resurrecting-a-28-4-banger.html#Post394209
6. Who knows how long this engine has been sitting after it was rebuilt. While the oil pan is off, I suggest squirting some 10-30W oil around all the bearings before closing up the bottom end and smearing some assembly grease around the cam lobes.
Aside from the above stuff about the bottom end, make sure that all bolt threads that go through the block and stick into the 'splash zone' of the oil mist have some thread sealer on them. I used Permetex #3.
Has the pilot bearing been replaced? Maybe stick a new one in there just to be safe.
Regarding the alignment of the clutch, I seem to remember that a wood pilot bearing tool from an AD pickup is the correct size for the old four bangers. ;-)
Does your truck have the original carbon plate throwout bearing? I suggest replacing it with a newer-style permanently sealed ball bearing type of throwout bearing. The carbon disks tended to overheat and cause issues. The newer style definitely gives you peace of mind against this problem.
When you put the transmission in place, it will be loose between the chassis rails. There are 1/8" shim plates that drop down over the mounting bolts that will take up the slack and make for a tight fit. See the pic below for a view of the shims I'm talking about.
Speaking of putting the tranny in, make sure the truck is up on jack stands and the rear stands are supporting the chassis, not the rear axle. This will allow the rear end to hang down far enough to provide more space for getting the u-joint bolted together. This goes for any vehicle that has a torque tube.
That's all that I can think of at the moment.
Cheers, Dean
Chevy transmission mount shims
Dean 'Rustoholic' Meltz
Lurch: 1927 1-Ton Chevy Cattle Truck
Old and ugly is beautiful! -- The Saga [stovebolt.com]
Lurch's Gallery
Justin: 1928 Chevrolet AB Canopy Express
If the block was that weak not to be able to hoist thru there, then the block probably wouldn't be strong enough to run.
Congrats on your new project! You're off to a great start with that one! A heckuva lot more to work with than my '28 LO.
Brian
'51 Chevy 3604 Project
'28 Chevy LO basket case
'83 GMC Sierra 4x4
Fox Offline
Very cool truck, John. That red will look amazing when it’s assembled. Assembly manual? I think you should try to find and buy another one just like it for a “puzzle box” to see how it goes together! 😁
In the Stovebolt Gallery [stovebolt.com]
More pictures here [photos.app.goo.gl]
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- Rusty- the puzzle box lid for the C10.
1950 Chevrolet 1300- in progress to shiny.
1962 AMC Rambler American- my wife’s
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
AD Addict
That would be the worlds most expensive Assembly Manual! 🤣
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
Updated to: 12v w/alternator, HEI & PCV
Dean .... Great. Thanks. I wonder who I gave my engine stand to .,...
Brian ... Hmmm ... I may have some left overs you could use ...
Fox -- That thought *has* crossed my mind. Either that or providing Dean an all expenses covered vacation to the East Coast ...
Will Rogers
In Project Journals
1949 Chevrolet 3804
In Gallery Forum
1973 IH 1310 Dump
Man!! All of this is starting to sound like work.
Building an old truck like that doesn't count as work. wink
Moderated by  John Milliman, Phak1
