Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
1 members (second2nun), 41 guests, and 3 robots.
The Zone
Forums65
Topics123,445
Posts999,565
Members47,279
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1499889 Sun May 07 2023 03:38 PM
Working on a friends 51 GMC I am installing a 350 with a four-speed and I need to know if this crossmember needs to come out I have a transmission crossmember for it
I have already installed a mustang two front suspension
52-Mobil #1499905 Sun May 07 2023 05:11 PM
Frame flexing at the cowl area can become a problem if that crossmember is removed completely. That's especially true if you're planning to run some kind of high torque engine. I'd suggest cutting the center out of the original part and dropping it a couple of inches with flat plate and square tubing. Use a piece of all thread to keep the frame rails from spreading while you're whittling on the crossmember.
Haha! Same as framing a house. Run a string line along the frame so you have visual confirmation that everything stays square and true.
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1956 Cadillac Sixty Special Fleetwood (The Godfather)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
52-Mobil #1499941 Sun May 07 2023 09:16 PM
I was asking if it has to come out
I definitely don’t want to remove it or redo it if I don’t have to
Wondering if anyone has done this before
52-Mobil #1499947 Sun May 07 2023 09:27 PM
Depending on the kind of bellhousing you're using, there may or may not be enough clearance for the bellhousing or transmission. Certain automatic transmissions will need to have the center of the crossmember lowered and reinforced to keep the angle of the crankshaft and driveshaft correct. Most engine/trans assemblies aren't level with the ground- - - -there's a little bit of tilt toward the rear. The engine centerline and longitudinal tilt should have been mocked up with a bare block and an empty transmission case before the M-II suspension was welded up.
52-Mobil #1500040 Mon May 08 2023 12:25 PM
I my case I have a SBC 383 with an NV3500 5 speed (rather than your 4 speed) but I needed to drop the center section of the cross member to clear the transmission. The only way to really tell with your combination is to try it. Much easier with the cab removed but even with the cab in place you can determine if the engine-transmission combination will clear the cross member byt trying to get the engine into location.
1949/50 3600 Project
52-Mobil #1500063 Mon May 08 2023 03:09 PM
Unrepentant VW Lover
I moved this thread to the HiPo shop because it seems to me to be more of a performance upgrade modification/fab question than strictly an engine question .... probably more people who have done this before will be in the hiPo forum ...
smile
"If there are no dogs in Heaven, then when I die I want to go where they went."
Will Rogers
1927 Chevrolet Capitol 1-Ton Express -- A work in progress
In Project Journals
1949 Chevrolet 3804
In Gallery Forum
1973 IH 1310 Dump
2014 Ford E-350 4x4 (Quigley)
In Daily Driver Gallery
52-Mobil #1500157 Tue May 09 2023 02:22 AM
Jeff, that crossmember question has come up before, and I’ve responded to it before, with these same pictures. I’ve got a 327 in mine with a 700-R4. The crossmember was in the way so I cut it out, but I wanted some degree of support in its absence. Nothing fancy: just a 1/8” thick steel tie plate and coupler nut spacers bolted into those eight horizontal holes that the factory has already pre punched for you. I’m sure some of the guys on the site again will find fault with my engineering, but fwiw, it’s held up for the last 20 years with no failure. You can maybe even come up with a beefed up version of the idea. Good luck, Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
52-Mobil #1500214 Tue May 09 2023 05:02 PM
I am at the same point. I have a couple friends with the mid 60s trucks that have removed them in order to install BB in them. The insist there are no problems doing this.
1966 C-10 Step Side
A Project Journal
52-Mobil #1500860 Mon May 15 2023 05:08 PM
In the case of AD trucks. The crossmember is multi function. 1) it supports the engine/trans. 2) provides support for the front leaf springs. 3) provides frame ridgity for the cab mounts.
In the case of doing a MII crossmember and drivetrain swap, you can erase all of the above. You're putting a crossmember in where there wasn't one before. Also, more than likely, adding a second crossmember just behind the original.
Take a sawzall, whack it out, never look back.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Page 1 of 2 1 2
