The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 members (Dragsix, 66flea, AlanV, carbking, 3 invisible), 274 guests, and 3 robots.
Forums50
Topics121,474
Posts973,858
Members43,939
Most Online1,229
Jan 21st, 2020
Image Posting Policy
3-link suspension in AD
#14994 Fri Feb 06 2004 06:27 AM
OlBlue Offline OP
This is a response for Marlo to a post in the Body forum.
I have been working on a '60's Chev pickup rear suspension swap into an AD frame over the last couple of years. ( I work kind of slow.... ).
Here is a link to pictures of my frame.
\'49 chassis with \'66 pickup rear suspension
I made drawings of the frame and the '66 suspension in a Computer Aided Drafting program (AutoCad) and then proceded to make the mods to the frame based on the drawings. The only obstacle was that the spring pockets are right at the outside edge of the frame on the '49. I made the cut in the bottom flange right out to the vertical section of the frame and then welded in a curved piece of metal that tied the bottom flange into the 2X4 cross member. The pictures at the link posted above show the installation of the '66 cross member that anchors the trailing arms and the new transverse link.
Give a yell if you've got more questions. My wife got a new digital camera for Christmas so pictures are a lot easier to post than they were when I made these pictures
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
Re: 3-link suspension in AD
#14995 Sat Feb 07 2004 02:53 AM
Ol blue those pics were fabulous... That is exactly what I want to do! Seems really easy at first then you realize the cutting and the measuring. I really appreciate the help and I will give you a yell when I get started doing mine. Great job and thank you again for the wonderful pics.
Marlo
#14996 Sat Feb 07 2004 02:56 AM
OlBlue Offline OP
Marlo,
Look forward to hearing from you.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
#14997 Thu Feb 26 2004 06:52 AM
WOW! Hats off Olblue, that is some awsome engineering! I started to do something very similar on my girlfriends '48 but got overwhelemed at the amount of work, and the fact that the trailing arms would hit the gas tank that I really didn't want to move (she liked it in the stock spot, and its her truck) so I've chickened out and ordered a triangulated rear suspension. Once again, nice work! Any chance your going to post your cad drawings? wink Thought I'd ask.... :p
#14998 Fri Feb 27 2004 04:50 AM
OlBlue Offline OP
Thanks for the kind words! There's only a couple of dimensions that are critcal and suppose I could put a sketch together one of these days.
I have a '38 1-1/2 ton truck with a hydraulic unit similar to the one on your COE. The hydraulics (pump, cylinder and valves) are all in a single unit. The PTO has a long driveshaft back to the unit.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
Moderated by  Woogeroo
