Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
17 members (32vsnake, Gdads51, 68ironhead, baldeagle, Flatblu4748, 3100Cummins, 1 invisible), 138 guests, and 3 robots.
The Zone
Forums65
Topics123,445
Posts999,543
Members47,279
Most Online1,229
Jan 21st, 2020
Page 3 of 3 1 2 3
I
IDidIt Offline OP
Mike - Saw that small port on my unit. While the port tube was cast it was never drilled through into the housing. I stuck a drill bit in there and it is solid at the bottom. In other words blocked and nothing was ever hooked to it that I could tell. I made an assumption that the box was dual purpose and they either drilled it out for one purpose or left it as-is. I had the speedo gauge cluster out of my truck but didn't see anything there that vacuum would hook up to nor can I figure out - if it did - how that would actually work. The correction of speed would have to be accomplished in the mechanical cable somewhere between the speedometer and the transmission. Does that sound correct? Speedo does work but could not say if it is accurate in either high or low. Can you feed me a little bit more detail on this? Thanks
Mitchell Barlow
See if these factory drawings answer your questions...detail "B" shows the speedometer adaptor.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod [stovebolt.com]
1956 8400 Wrecker w/Holmes 525 [stovebolt.com]
1956 9200 Tractor w/Allison Automatic [stovebolt.com]
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 CJ-5 Navy Jeep
Hughesville, MD
Page 3 of 3 1 2 3
