Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
12 members (55shaker, festerhairball, 2ManyTrucks, dougs, 4 invisible), 143 guests, and 4 robots.
The Zone
Forums65
Topics123,394
Posts998,891
Members47,253
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
That's if he measured his bolt circle correctly.
I used to have a chart that showed bolt circle measurements for odd numbered lugs. If you measure across from 1 to 3 or 1 to 4 on a 5 bolt pattern it would tell you what the diameter is.
Probably can find it on the internet.
Also, If you own a compass, cut out a 5"diam circle from a piece of cardboard and see if it lines up with the centers of all the lugs. Make a 4 3/4" circle as well and see what happens.
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1956 Cadillac Sixty Special Fleetwood (The Godfather)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
Agreed.
He's said 5 on 5 a number of times, but hasn't said he has measured.
5-LUG BOLT CIRCLE
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Why would I measure when I put a set of aftermarket rims that are a 5x5 pattern on my 50 ? Took them off my obs put them on the 50
Maybe your rims are also 5 on 4-3/4" as well. Have you verified that? Not trying to be difficult, but if you haven't measured, you can't be sure. We're just trying to help. ohwell
"My mind is made up- - - - -don't confuse me with facts!"
When I have explained that I put a set of rims that came off a Chevy Silverado that has a 5x5 pattern not sure what is to measure ? Think you guys want to be so right . Someone please show me a picture of these drums that you say I have . Again just trying to find a match asked for help , but just seems as if everyone is right and I don't know what I'm speaking about . Thanks guys
I wasn't saying I was right, just suggesting that the hubs and drums might have been off a 51-54 chevy car. They will fit on a 1/2 ton truck spindle. But they are 5 on 4-3/4. I gave you all the information I have. You kept saying they were 5 on 5 pattern, but never said you'd measured the bolt circle, and your post today was the first time you mentioned they came off a Chevy Silverado, but without a year of that truck, there's no way to confirm what the bolt pattern might be (later Silverados ~2000+ could have a metric pattern.) ohwell
Sorry that you feel bad about this. If I knew what your brake drums were, I would certainly tell you.
The more information you give us, the easier it is to help you. For instance Brake drum ID and width would help.
Maybe what you'll need to do is take the hub and drum to your parts store and compare with what they have. Possibly a '70 or '71 Chevy truck would fit. 1971 C10's had 5 on 5 wheels, but had disk front brakes. 1965-1969 C10's had 11" x 2" front brakes but 6 on 5.5 wheels.
Page 2 of 2 1 2
Moderated by  klhansen, Rusty Rod
