Major event in Virginia
Look Look Look
ODSS Bolters
head to
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the details.
Searching the Site
14 members (2-Ton, 52Carl, D B Cooper, glennj3, carbking, 1 invisible), 126 guests, and 3 robots.
The Zone
Forums65
Topics123,370
Posts998,595
Members47,287
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
SNOYL #1495506 Thu Apr 06 2023 12:55 PM
Originally Posted by SNOYL
Took care of the ring, tinny sound, truck is much quieter. NO moisture issues. We use spray foam a lot in my trade, it is highly over rated.
Never would have guessed that fluid film would deaden sound. Would be super easy to get it in places impossible to access with other products.
Ferris Bueller #1495540 Thu Apr 06 2023 04:01 PM
Took care of the ring, tinny sound, truck is much quieter. NO moisture issues. We use spray foam a lot in my trade, it is highly over rated.[/quote]
That being said I can easily build a flex hose (spray 360) for some undercoating to be sprayed into these areas. Once bonded it would not absorb moisture?
1966 C-10 Step Side
A Project Journal
Ferris Bueller #1495615 Fri Apr 07 2023 12:06 AM
Yes, you can buy everything needed to spray it, a small hole in the doors and a plug . In the roof area we went in thru the rearview mirror hole and sunrises holes, about a three foot hose with 360 spray. I was impressed. I don't think there is anywhere you can't get it. It is impressive stuff.
Ferris Bueller #1495637 Fri Apr 07 2023 02:45 AM
I used ABESCO fire stop expanding foam to seal the openings between the engine compartment and the rear quarter panels on my VW beetle. That was 15 years ago and there is no evidence of rust and it is an effective seal. This foam has very little water absorption and is typically used to seal around ducts and electrical conduits in fire rated walls and floors. I'm not sure I would use it to completely fill a cavity but it expands to fill a large opening similar to Great Stuff. It is not the same as Great Stuff. The two part foam would be better if you need to fill a sizable cavity but I don't know about it's flammability.
Mark
59 fleet #1495754 Sat Apr 08 2023 12:18 AM
Here in northeast Pennsylvania water absorption equals rust, why I used fluid film. Unexpected benefit was sound reading in those areas, roof, doors, box sides even hood area. My guy is a professional and I am very happy with the results. It even surprised him, I think I'm the only one that would a vehicle 50 plus years old and fluid film it.
Page 2 of 2 1 2
Moderated by  Hambone
