Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
10 members (Hanks custodian, festerhairball, Jlsandov321, Flatblu4748, Djg, 1 invisible), 129 guests, and 3 robots.
The Zone
Forums65
Topics123,394
Posts998,889
Members47,253
Most Online1,229
Jan 21st, 2020
#1494032 Sun Mar 26 2023 10:20 PM
I have an active post over in the Electrical forum, but I posted here just in case anyone can identify the origin of this set up. I’ve got two GM horns mounted on the driver’s side inner fender of my 1957 Chevy 1/2 ton. The horns are high and low tone. Here’s a picture…
LAJones48 #1494036 Sun Mar 26 2023 11:10 PM
Sir Searchalot
The origin of that setup is someone's garage. Your truck came with one low note horn on drivers side radiator "tie bar". The only normal size truck with two horns was the Cameo.
Also we can not see a black bracket on a black inner fender background in a dim lighted photo. But that is OK, it's not a factory item. Don't think any one/dealer would sell a bracket with horns close together and not mounted up front for proper volume.
Interesting fact about the year 1957 Chevy truck. 65% of them, including $45,000 Barrett Jackson auction trucks and trucks in our gallery (40%), have the fender emblems on backwards.
LAJones48 #1494063 Mon Mar 27 2023 01:50 AM
Look on the cast side of the horns for a 3-digit number...that will help ID the horns. It will also be marked 12V. All of the GM cars used the Delco-Remy sea shell horns, so that set could have come off of one of the big cars from the late 50's.
I believe 1957 was the first year for the stamped steel cover like your right horn has...the earlier horns had a round (half of a sphere) cover.
The HI note horn was an accessory on the TF trucks and was mounted on the passenger side of the radiator core support...it's a mirror image of the LOW horn
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod [stovebolt.com]
1956 8400 Wrecker w/Holmes 525 [stovebolt.com]
1956 9200 Tractor w/Allison Automatic [stovebolt.com]
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 CJ-5 Navy Jeep
Hughesville, MD
LAJones48 #1494071 Mon Mar 27 2023 02:25 AM
Thanks guys for the info. I’m leaning toward moving them to radiator support especially to separate them . That makes sense to me.
Moderated by  klhansen, Rusty Rod
