Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
3 members (Shof, Tony D El, 2ManyTrucks), 96 guests, and 3 robots.
The Zone
Forums65
Topics123,394
Posts998,891
Members47,253
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
WE b OLD #1493776 Fri Mar 24 2023 10:18 PM
DES57. It is a double hitch. The plate is attached to a hitch bar which is removeable and i keep a replace ment in the cab if I want to tow something, which as happened once in the last 15 years.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck in the Gallery [stovebolt.com]
2017 Buick Encore
See more pix [photos.google.com]
WE b OLD #1493811 Sat Mar 25 2023 10:06 AM
With the numerically low rear end gears, and the overdrive transmission you are running, you should go with whatever tires have the smallest diameter. This will make your overdrive more usable than with the taller tires you have on the rear now.
WE b OLD #1493812 Sat Mar 25 2023 10:28 AM
WEbOLD I had a pair of polyglas goodyears,raised white letters on the ground since 1971. Always in out of the weather and sun,just changed them last summer.A friend gave me some tires on wheels 25 years older than that.
WE b OLD #1493815 Sat Mar 25 2023 10:44 AM
54Carl. It has a Nova rearend with 2.73 gears. at 70 on the highway it runs 70 at 2100 rpm. The only apprehension is I will have recalibrate the speedo not a fun job.
2017 Buick Encore
WE b OLD #1493823 Sat Mar 25 2023 12:24 PM
Search the Internet for "ratio adapter for a speedometer drive gear".
You can determine the ratio adjustment you need by calibrating how much you are off in a test run on a 1/10 mile marked highway (maybe a well marked Interstate).
Maybe someone here can most a link to the procedure (or, a link to a post here that describes the procedure)?
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
WE b OLD #1493824 Sat Mar 25 2023 12:28 PM
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1956 Cadillac Sixty Special Fleetwood (The Godfather)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
fixite7 #1493827 Sat Mar 25 2023 12:56 PM
Fixite7,
As many have shared in other discussions, don’t crawl under that truck, even with all four tires on the ground, without blocking it. Tires that old can blowout at anytime just sitting there.
1957 Chevy 3200
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights
WE b OLD #1493829 Sat Mar 25 2023 01:00 PM
The technique is shown here. [bobsspeedometer.com]
I have easily and safely used mechanical ratio adapters (on Stovebolt trucks).
Tim
WE b OLD #1493836 Sat Mar 25 2023 01:23 PM
Curmudgeon
Wow, a 4 subject discussion in the same posting.
I like having the same tires size on all 4 wheels that way I only have to carry one spare tire.
WE b OLD #1493837 Sat Mar 25 2023 01:33 PM
Gearhead, Moderator for The Swap Meet and General Truck Talk
While this conversation has taken a little ride around the globe of things related to the original topic, I think Ron (WE b OLD) has all the helpful info he needs to make his tire choice decision.
If he wants to continue to talk tires and other "Driveline" related stuff, feel free to start a new conversation there.
This one is now locked down. On to other GTT conversations folks. thumbs_up
Hope everyone has a great weekend! shake
Dan
Dan
1951 Chevy 3 window 3100 (My Grandpa's hunting truck)
1966 Chevelle (Wife's Hot Rod)
2013 Chevy Silverado (Current daily driver)
US Army MSG Retired (1977-1998)
Com Fac Maint Lead Tech Retired (1998-2021)
Finally time to get to work on my Grandpa's (now mine) truck!
Page 2 of 2 1 2
