Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
14 members (Charles in CA, Gdads51, Djg, 78buckshot, coopertechparts, Flatblu4748, 1 invisible), 650 guests, and 5 robots.
The Zone
Forums65
Topics123,415
Posts999,170
Members47,264
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
Authorized Pest
Had to add this since we are here.
One of my favorite shots. Our Stovebolt at work.
1965 GMC-Darley Tanker Truck
Peggy M
“After all, tomorrow is another day!”—Margaret Mitchell, Gone with the Wind
Share knowledge and communicate it effectively. ~ Elihu
Marc, Welcome to Stovebolt wave
The red cast housing is the fire pump primer pump/controller. It's job is to allow truck engine vacuum to be used to purge the air out of the suction side of the main pump as well as the draft hoses. The controller has a float assembly that prevents pond water from being sucked into the engine once the pond water reaches the main pump...just like a carburetor float/needle seat valve. New fire engines use electrically driven primer pumps as diesel engines don't make vacuum, so all that stuff is obsolete now.
Like John said, you can/should remove all of that to clean up the engine bay...I'm sure there is someone in the world that would take that stuff off your hands, but it's probably not worth what it would cost to ship it.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod [stovebolt.com]
1956 8400 Wrecker w/Holmes 525 [stovebolt.com]
1956 9200 Tractor w/Allison Automatic [stovebolt.com]
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 CJ-5 Navy Jeep
Hughesville, MD
Can't thank y'all enough! Yeah I can't wait to get the old 401m running. We have 90% of the pump stuff off just actuator and block under carb to go. Whoever removed the old bed and other components done a sloppy job lot of hot wires were cut and left hanging so really want to take care of the loose ends before throwing power to the system. (Dont want to call a new fire truck out for my old one lol). It really makes me feel a lot better about those parts though. I am going in a somewhat rat rod direction so some of the brass components may get polished up and find new purpose. (Kind of seeing that brass tube turned into a light bar). Again can't thank yall enough. Peggy M has been a huge help and made me feel welcome.
1967 GMC 7500
See my Project Journal
Keep 'em shiny side up!
Thank you sir! Between you and John yall have answered more than two weeks of internet searches and even harassing all my mechanic buddies at the penske shop we use. I'm probably going to save the Brass components and repurpose them somehow but just scrap the rest. I was telling John now it's just getting the last few bits off and chasing down the wires they left hanging and getting all that squared away.
Again thanks so much now I can have a clear conscience about not trashing something and get down to business.
1967 GMC 7500
Authorized Pest
Ok. From here, start posting where you need to be. Like electrical, engine, etc.
We even have a HIPO forum, if you got the rod route. Lots of fun people in there, too.
[ Thanks Mike B .... wink ]
Peggy M
I've got an American LaFrance pumper on a 61 GMC pug nose chassis. It's running the 401 V6 and a direct drive 5th. gear Clark transmission. Since the tank has a big hole rusted in it and most of the plumbing is missing, I've got plans to remove the fire bed and replace the driveline mounted pump with a 3 speed Brownie transmission. That will give me 15 forward speeds including overdrive in 5th. and maybe slightly better gas mileage- - - -from outrageously bad to merely horrible, probably! I'll install a commercial 5th. wheel and a goose neck trailer hitch, and pull any trailer I feel like backing up to! That project is about 10th. in line right now!
Page 2 of 2 1 2
Moderated by  69Cuda
