Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
1 members (baldeagle), 68 guests, and 3 robots.
The Zone
Forums65
Topics123,445
Posts999,567
Members47,279
Most Online1,229
Jan 21st, 2020
Page 2 of 3 1 2 3
OH47Pickupman #1492791 Sat Mar 18 2023 12:36 PM
My ‘47.1 one ton had singles, also.
Ed
Possum #1492818 Sat Mar 18 2023 04:34 PM
Possum I'm not a ton expert,had I think 2 in my fleet of 30 in about 50 years. Correct me if I'm wrong the ton trucks had a screw on hub cap (the little one about 2 1/2 inches) with a hex made on it maybe 8 flats. 3/4 ton had a drive on cap like a 3100 on the front hubs. I guess we'll see if oh47pickupman lands this one.
EdPruss #1492851 Sat Mar 18 2023 08:21 PM
Ed Pruss Those are the same wheels my 51 3600 has on a rear axxle installed by a previous owner to haul heavy canned milk.Added spring leaves too. I somehow missed the fact that my ton wheels (same as yours ) are chevy. After several years needed tires,my local tire guy said since that is not a hiway truck we could put on rib-imp worth the money. I cleaned them up with a needle scaler painted with por 15,there still just fine,sleep in out of the weather.
Possum #1492896 Sun Mar 19 2023 01:38 AM
Originally Posted by Possum
Just because it doesn't have duals doesn't mean its not a 1 ton. The 9' bed came on 1 tons with single rear wheels, like my '58.
My 1950 1 Ton doesn't have duals!
1950 Chevrolet 5-Window Canadian manufactured 1-Ton with Dump Bed / Hoist
In the Stovebolt Gallery [stovebolt.com]
More pix on Photobucket [s1281.photobucket.com]
You will never stop learning new things, no matter how old you are.
fixite7 #1493075 Mon Mar 20 2023 02:25 PM
Rustbucket Ranch
My truck has the cap that taps on, I think it would be the same for oh47pickupman's '52 as well.
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
OH47Pickupman #1493083 Mon Mar 20 2023 02:54 PM
Unrepentant VW Lover
According to the Dealer Data Book, on the 3800 model ADs (1-tons), DRWs were an option available on the:
3802/3812 -- Flat faced cowl, and cowl and windshield
3803 -- Cab and Chassis
3808 -- Cab and Chassis with platform body (Flatbed)
3809 -- Cab and Chassis with stakebody
Not available on:
3804 -- Pickup
3805 -- Panel
3807 -- Canopy Express
"If there are no dogs in Heaven, then when I die I want to go where they went."
Will Rogers
1927 Chevrolet Capitol 1-Ton Express -- A work in progress
In Project Journals
1949 Chevrolet 3804
In Gallery Forum
1973 IH 1310 Dump
2014 Ford E-350 4x4 (Quigley)
In Daily Driver Gallery
OH47Pickupman #1493085 Mon Mar 20 2023 02:56 PM
On 1 tons the front wheel hubs differ from single rear wheel to dual rear wheel. The hub in the post above would be a single rear wheel. John
1949 gmc 1-ton
John Milliman #1493104 Mon Mar 20 2023 04:09 PM
Not available on:
3804 -- Pickup
3805 -- Panel
Probably because the "availables" didn't have rear fenders and the "not availables" did.
'57 GMC 102, Original 347 V8, HydraMatic, 3.08 rear gear, added A/C, disk front brakes, HEI, AFB carb, '98 Honda Black Currant paint. T-boned and totaled 10/13
'52 GMC 152 Stake Bed, Original 228, SM420, added A/C, disk front brakes, '67 Chev 3.55 rear gear. Gets used as a real truck.
OH47Pickupman #1493564 Thu Mar 23 2023 08:51 PM
Mechanically, the one-tons are a different animal from their 3/4-ton cousins. The frame is the 1-1/2 ton one with pickup-specific axles and wheels, same wheel base. Springs, front and rear, are 2 inch, like the 1-1/2 ton; driveline is open with a carrier bearing in the middle, like the 1-1/2 ton; Front axle is unique to 1-ton as are king-pins and hubs, tie-rod-ends and drag link. Brakes are unique. Look for Bendix brakes, with which some of the earlier one have been retro-fitted. That's worth several hundred dollars extra. All in all, its a much heavier duty pickup and they are hard to wear out. With care it'll likely outlast any of us.
1951 3800 1-ton
'62 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971.
In the DITY Gallery
OH47Pickupman #1493639 Fri Mar 24 2023 03:13 AM
Spot on, Tommy! Here's my unrestored '49 3804 (the Stovebolt.com flagship smile ) working today. It is a much happier truck with some weight in the back. Huck brakes and bias plys even ...
3800's rock!
Unloading at the Stovebolt HQ woodpile.
Ole Charlie is squatting a bit -- handled the load just fine.
Partially unloaded. It was all white oak.
Will Rogers
In Project Journals
1949 Chevrolet 3804
In Gallery Forum
1973 IH 1310 Dump
Page 2 of 3 1 2 3
Moderated by  Dusty53
