Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
17 members (Dragsix, Djg, festerhairball, 58NAPCO3600, COCOE, 1 invisible), 191 guests, and 3 robots.
The Zone
Forums65
Topics123,394
Posts998,881
Members47,253
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1491920 Mon Mar 13 2023 06:39 PM
CBall Offline OP
Recently purchased a 1948 3800 and I believe it has a fire extinguisher mounted in the cab? The only issue is that when I opened it, the clearish liquid inside smelled of brake cleaner, gasoline, or something highly flammable.....Please dont mind the holes in the floor lol
CBall #1491923 Mon Mar 13 2023 06:47 PM
Older fire extinguishers used carbon tetrachloride. Highly hazardous stuff. Link [en.wikipedia.org] Please don't be sniffing it. big_eek
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
CBall #1491944 Mon Mar 13 2023 08:08 PM
Yep, that's a brass canister extinguisher, filled with Carbon Tet. It'd carcinogenic, but it also makes some if the best thread tapping lubricant that's ever been invented. Drain the canister and store the liquid in a tightly capped mason jar. Just have plenty of ventilation if you use it as a thread tapping lube.
CBall #1491969 Mon Mar 13 2023 10:43 PM
Moderator
Jerry is right about it being the best tapping fluid for steel and stainless steel!
But not on aluminum, it will gum up the tap and you will break the tap.
Don't ask me how I know.
Don
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
'46 2-Ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
1954 Plymouth Belvidere
'70 American LaFrance pumper fire truck.
1976 Triumph TR-6
CBall #1491980 Mon Mar 13 2023 11:14 PM
CBall Offline OP
Nice! Ok will do about putting it in an air tight container. I will also start looking around for a new label for it and polish it up!
CBall #1492019 Tue Mar 14 2023 02:30 AM
What make is it?
I have the same type , no label . Most are from 40' & 50's.
Mine polished up pretty good.
CBall #1492070 Tue Mar 14 2023 12:16 PM
“Grease Monkey” “Former herder of cats”
Carbon Tet was commonly used in the dry cleaning industry pre 1960ish. Scientists noticed a correlation between dry cleaners and higher death rates and began a study. The stuff was outlawed soon afterwards. There was a story floating around at the time of a man who picked up his suit from the cleaners and put it on the next day for work. Walked in the door of his business and dropped dead. Ambulance personnel noticed a strong odor of Carbon Tet on the body. As I said it was a story at the time, who knows if true or not.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
CBall #1492071 Tue Mar 14 2023 12:26 PM
This Pyrene fire extinguisher is in my old road department truck.
CBall #1492078 Tue Mar 14 2023 12:49 PM
Can those old extinguishers be refilled with modern stuff to be re-used?
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1956 Cadillac Sixty Special Fleetwood (The Godfather)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
CBall #1492093 Tue Mar 14 2023 02:06 PM
I don't know of a fire suppression liquid other than carbon tet that's stable enough to stay liquid without being pressurized in a sealed container. Halon comes to mind, but I believe it had to be contained in a pressure vessel. It's also almost impossible to find due to some sort of so-called health hazards .
Page 1 of 2 1 2
Moderated by  klhansen, Rusty Rod
