Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
8 members (Patharr, hokiecarpenter, DES57, Hotrod Lincoln, Leo, 1 invisible), 270 guests, and 3 robots.
The Zone
Forums65
Topics123,442
Posts999,498
Members47,277
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1489063 Wed Feb 22 2023 07:03 AM
They sure are proud of their kit, but I really like the idea of the snap together parts to experiment with for exhaust routing.
Price: Ouch [trick-tools.com]
I got a buddy to 3d print a few pieces as an experiment to see how well it would work. It was surprisingly effective, and at $0.30 per piece for filament I might consider making a full set when I am ready for exhaust work.
Though I did see that Holley had started making equal length cast iron manifolds/shorty headers for a few engines. That concept appeals to me as well.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Apache, long bed Fleetside, V8 w/SM420
Driveable but the rear axle needs work.
1959 Apache, long bed Fleetside that has been in the family for 25 years but in desperate need of love.
Fibonachu #1489096 Wed Feb 22 2023 03:27 PM
P.T. Barnum was a wise man!
Fibonachu #1489114 Wed Feb 22 2023 05:54 PM
We use defroster duct with holes punched in it so spray foam can be squirted inside. Once foam sets the tubes are plenty rigid to use as patterns for a tube bender. Pic of header for a Studebaker Golden Hawk---not something one can buy off the shelf.
[img]https://i.postimg.cc/xcrmtkCF/57-Golden-Hawk-Headers-016.jpg[/img] [postimg.cc]
Evan
Fibonachu #1489115 Wed Feb 22 2023 06:02 PM
I believe I went directly to ICE Engine Works and just got the pieces I needed instead of a kit. Much cheaper that way. Worked extremely well.
Fibonachu #1489119 Wed Feb 22 2023 06:37 PM
I am much too cheap to actually buy the kit, but if you did a lot of custom/tight headers I could see it being worthwhile.
A lot == your day job
Fibonachu #1489206 Thu Feb 23 2023 04:28 AM
I'll have three or four projects coming up where I'm going to build my own stuff. That was enough for me to justify the purchase.
Fibonachu #1489223 Thu Feb 23 2023 06:18 AM
Sir Searchalot
Fibonachu #1489278 Thu Feb 23 2023 06:59 PM
Lol. Maybe not so much. A coat hanger would do the same and cause the same problems. Been there, etc., etc.
Fibonachu #1489280 Thu Feb 23 2023 07:01 PM
Let's be honest, we have all seen sketchier things than Bartamos's links on the road...
Fibonachu #1489325 Fri Feb 24 2023 12:12 AM
One of the neatest exhaust systems I ever saw, the owner cut the pieces to fit, super-glued them together to verify fit, and then welded it all up when he knew it all worked together. You had to see the finished product to believe it.
Page 1 of 2 1 2
Moderated by  MNSmith
