Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
4 members (LexAdmn, greenie-reddy, John Dlugos, baldeagle), 40 guests, and 3 robots.
The Zone
Forums65
Topics123,445
Posts999,567
Members47,279
Most Online1,229
Jan 21st, 2020
Page 3 of 4 1 2 3 4
Hotrod Lincoln #1489818 Mon Feb 27 2023 05:01 PM
Other than being outrageously expensive eye candy, does all that stuff, heads included, have any practical purpose?
Alone they may or may not make a difference. If you have good flowing heads, headers generally allow you to size up a jet or two. According to a excellent friend who builds engines and has had many dyno hours on his builds pushed me to go with headers vs my rams horns. He even had the numbers showing the HP and TQ curves for 1 1/2 vs 1 5/8 tubes. I opted for 1 1/2 as I doubt I will be running at the high end of the rpms and the mid range tq and hp were higher vs the 1 5/8 until 5k.
All that said I hate headers for the sealing issues. Sampson advertise no gaskets to the head and I have bought copper ones for the collector.
1966 C-10 Step Side
A Project Journal
Ferris Bueller #1495362 Wed Apr 05 2023 03:01 PM
I have not previously encountered someone who
a) has purchased really nice headers
b) hates headers
So it goes.
Age 68 is not too late to start hot rodding , right?
Ferris Bueller #1495367 Wed Apr 05 2023 03:43 PM
After spending approximately 65 years building engines, and running dozens, if not hundreds of dyno tests, I have yet to document any sort of usable power gains with headers in an RPM range that the average street-driven engine ever sees. Therefore, I will stand by my opinion that headers, and other visually appealing accessories have no practical purpose. They usually have noticeable downsides such as actually reducing performance in some areas, or increasing under hood temperatures, leaking, and burning spark plug wires. "Your mileage may vary!"
Waveski #1495436 Wed Apr 05 2023 09:40 PM
b) hates headers
So it goes.
Bought a nice set of Hooker long tubes for my 83 Bronco. Hated them. They could not keep a gasket in them. Had to remove to get to the starter.
Bought a nice set of Headman shorties for my 94 Bronco. Hated them. I wrapped them, and they rotted out in a year. I went back to the OE manifolds.
Bought a nice set of ASM equal length equal bend shorties for my 95 Impala SS. It was a 10hr job to get the pass side one on or off. Hated them.
Now I have purchased a nice set of Sanderson. The rear plug is impossible to get to.
1966 C-10 Step Side
A Project Journal
Ferris Bueller #1495447 Wed Apr 05 2023 10:47 PM
The definition of insanity is to keep doing the same thing and expecting different results.
Just sayin'...
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1956 Cadillac Sixty Special Fleetwood (The Godfather)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
Ferris Bueller #1495476 Thu Apr 06 2023 03:53 AM
Ferris: have you gotten to check your cab clearance yet?
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Apache, long bed Fleetside, V8 w/SM420
Driveable but the rear axle needs work.
1959 Apache, long bed Fleetside that has been in the family for 25 years but in desperate need of love.
Fibonachu #1495514 Thu Apr 06 2023 01:25 PM
No I have not. I figure once I get the rest of the front clip internals panted and bolted on I will set the cab in place, mount the doors, and begin final bodywork before cab paint.
I hope to get pleasantly surprised with enough room for everything at that point. I do think it will be ok, but I am worried about the clutch hyd lines, and how/where I am going to fit a muffler and diverter under the cab to exit out under the step. Even if I went out the back there is no room due to the factory 3 link.
Otto,
You are correct, but the OE rams horns do not mate well with the new style head. I had few options.
1966 C-10 Step Side
A Project Journal
Ferris Bueller #1495624 Fri Apr 07 2023 12:54 AM
I knew that popcorn time would come.
(Honest disclaimer: I hated my headers the day I changed oil on my 283 for the first time. Swapping filters was a very bad experience. I have made peace since then. Someone else will wrestle filters next time.)
Ferris Bueller #1495628 Fri Apr 07 2023 01:08 AM
A remote filter would solve that problem, but needing to do stuff like that to resolve a self-inflicted inconvenience just reinforces my original commentary about running headers when they do nothing for improving overall performance.
Ferris Bueller #1495629 Fri Apr 07 2023 01:19 AM
Originally Posted by Ferris Bueller
Otto,
Haha!
The only vehicle I've ever owned with headers is the 1976 F150. Previous owner installed them. It's a 460 so there's no room under the hood as it is. Those stupid things are so hot it's ridiculous. They're also about 1/16" away from the steering gear so when I had to have it rebuilt it was a chore getting it out.
1979 Ford F-100
Page 3 of 4 1 2 3 4
