Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
2 members (baldeagle, klhansen), 45 guests, and 5 robots.
The Zone
Forums65
Topics123,445
Posts999,565
Members47,279
Most Online1,229
Jan 21st, 2020
Page 2 of 4 1 2 3 4
TUTS 59 #1488000 Wed Feb 15 2023 08:58 PM
[quote=TUTS 59]I'm sure they will clear the cab but I'll bet the toe board will get plenty warm. quote]
May have to wrap them? It is a ceramic coating. but I doubt it will keep it cool enough.
1966 C-10 Step Side
A Project Journal
Ferris Bueller #1488014 Wed Feb 15 2023 10:57 PM
Crusty Old Sarge
Originally Posted by Ferris Bueller
I hate headers. But doing a cost and time analysis between all options this was the best option due to Blue Print head design. These are supposedly no gasket headers? We will see, but I plan on using gaskets.
I have headers and opted to use copper gaskets, a little more money but much better sealing. Don't forget to use good header bolts and enough exhaust mounts to spread the load out over the system.
Craig
"Living life in the SLOW lane"
Come, Bleed or Blister something has got to give!!!
'58 Viking 4400, 235, 4 Speed (Thor)
Ferris Bueller #1488114 Thu Feb 16 2023 08:14 PM
I just got a e-mail about another delivery from Sanders? Maybe they sent me the wrong ones? Won't break my heart to have a second set to sell?
1966 C-10 Step Side
A Project Journal
Ferris Bueller #1488120 Thu Feb 16 2023 09:22 PM
Did Blueprint tell you ahead of time that your stock manifolds would not work? That seems like an odd design choice that you should have been made aware of up front.
I couldn't tell from your original post if you knew or not.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Apache, long bed Fleetside, V8 w/SM420
Driveable but the rear axle needs work.
1959 Apache, long bed Fleetside that has been in the family for 25 years but in desperate need of love.
Ferris Bueller #1488161 Fri Feb 17 2023 02:03 AM
I don't remember having that conversation with them. It was an assumption on my part that all sb stuff fit other small blocks. I asked dang near every other question there was but that one.
1966 C-10 Step Side
A Project Journal
Ferris Bueller #1489062 Wed Feb 22 2023 06:56 AM
Did you end up with another (or different) set? The more I look at your pictures, the more it seems like those collectors are really high and pointed more back than down.
Fibonachu #1489068 Wed Feb 22 2023 12:17 PM
Originally Posted by Fibonachu
[quote=Ferris Bueller]I The more I look at your pictures, the more it seems like those collectors are really high and pointed more back than down.
I received an identical set. I have everything set in place, and have used a tape measure and eyeball. I am going to have to set the cab down to make sure.
1966 C-10 Step Side
A Project Journal
Ferris Bueller #1489101 Wed Feb 22 2023 03:45 PM
Other than being outrageously expensive eye candy, does all that stuff, heads included, have any practical purpose? I've done several dyno runs that prove beyond a shadow of a doubt that aluminum heads produce measurably less torque at the flywheel than similarly equipped engines with cast iron heads, due to excessive thermal transfer to the cooling system instead of energy transfer to the pistons. They do make the heater work well, though!
Ferris Bueller #1489667 Sun Feb 26 2023 01:05 PM
Lord help me-
I have headers AND fiberglass body repair in my truck!!!
(What is “Blueprint“?)
Age 68 is not too late to start hot rodding , right?
Ferris Bueller #1489674 Sun Feb 26 2023 02:14 PM
I asked the same thing in another thread.
It's the brand name of a custom engine builder.
Previous owner repaired my floor with fiberglass, too. Doesn't look like the problem was too bad, though. It's all hidden by the mat.
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1956 Cadillac Sixty Special Fleetwood (The Godfather)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
Page 2 of 4 1 2 3 4
