jameschevypu50 While I am at the junkyard I watch for clean 8 mm plug wires,long ones,usually one end has what you need. Trim it to your length then ( I use NAPA plug wire pliers) put a boot and fitting like you need on the other . Make it a nice fit on your engine, the napa pliers do a pro job on that,important to lube them with ignition grease and if they are new need a little break-in. Done right you can't hardly rip em off of there !!! 4 or 5 sets running around here now. I use homebuilt HEI in all of my 216,235,261 engines they start hot,cold, doesn't take long.
