Don't press your luck!
 Sure, you know how to work on old trucks. Or maybe you're just starting in the hobby. Either way, safety is best learned through OPM (Other Peoples' Mistakes), not OJT!
Either as newly discovered wisdom, or a refresher, please read this article and live safely with your old truck!
Forums60
Topics128,762
Posts1,059,607
Members46,752
Most Online1,229 Jan 21st, 2020
Unrepentant VW Lover
Raven, Covey Leader .... Designate 2-Ton as new target. New target is 2-ton. Prosecute target with extreme prejudice. Authenticate Charlie Hotel Echo Sierra Tango Yankee, over.
"If there are no dogs in Heaven, then when I die I want to go where they went." Will Rogers
'49 Chevrolet 3804 '73 IH 1310 Dump '14 Ford E-350 4x4 (Quigley)
Break Break ....
Covey Leader to Raven, Covey Leader to Raven ... stand down. KLHansen is NOT target. Say again, klhansen is NOT target. Over. Thanks John  Raven, Covey Leader .... Designate 2-Ton as new target. New target is 2-ton. Prosecute target with extreme prejudice, over. Hopefully Don has a bunker at his place.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
OP
So, when I met the PO at his mountain top cabin the Jeep was inside the one car garage. This cabin looks finished from the outside, but has been a 25 year project and the garage floor is still dirt and the inside walls are unfinished waiting on electric and plumbing to be done. The owner goes inside to open the garage door leaving my son and I outside (my wife stayed in the truck)...we can see and hear he's having trouble lifting the garage door so I go over and grab the outside handle and yank the door up. Unbeknownst to me he had laid a 2x4 across the top of the door to keep the squirrels out and when the door went up the board came down hitting me right on top of the head...after a little in the field first aid which amounted to gauze an an ace bandage going under my chin and over my head we got our first look at the Jeep. Note, the door was heavy because he hasn't put the lifting springs on the door yet. I was told it was in running order, but discovered it had a dead battery, so the owner hiked down the hill to the road (300" long driveway that makes a 150' elevation change) and off to Tractor Supply for a battery. With the new battery in it wouldn't start, so out came the starting fluid and it ran as long as we kept spraying. Not long after that I asked my son to check the brakes...the pedal went right to the floor...that ended everything right there as there was no way to get it off the mountain without them working and it was now time for me to get real medical attention, so we headed home with my son driving and an empty trailer. Once we got close to my sons house the wife and I got dropped off at the Urgent Care facility...30 minutes later we were out the door with 4 staples in my head to hold the cut closed. The Doctor complemented the wife on her first aid skills and he said he'd be sending me out with the same style bandage she had used! Two weeks later the owner and I made the decision to have the Jeep professionally towed off the mountain and deposited down at the county road. This turned out to be a challenge for the tow truck driver as it took him three tries with his 4x4 rollback to get to the cabin and once there he had to use his snatch block and winch to turn himself around...after all of that he loaded the Jeep and took it to the road without further issues. With the Jeep now home I replaced both the fuel pump and filter and it runs great. I also replaced the Master Cylinder and flushed the brake lines and now have it stopping. Next up I'll be looking at the drums and rotors to make sure they are in good order. Chapter one of my adventures with this Jeep is done...LOL! Mike B
Drafted Moderator!
Don’t need a bunker Kevin, the VW lover is already in my sights and I have good intel that there is an insider in the JCM compound as we type, executing the precision removal of the VW lover from power! His thread stealing days are over!
Good find Mike and a great story. Please keep us up to date with pictures. Don
Of all the things I've lost in my life, I miss my mind the most!1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery [ stovebolt.com] '46 2-Ton grain truck '50 2-ton flatbed '54 Pontiac Straight Eight 1954 Plymouth Belvidere '70 American LaFrance pumper fire truck.
Kevin, I looked at your picture and you are swave and deboner standing next to that truk.
Solid Copy Covey Leader… beverage ops resumed… out.
Kevin, I looked at your picture and you are swave and deboner standing next to that truk. That's not me, Ron but the guy I corresponded with that worked for the Alaska Road Commission. When that pic was taken I was 4 yrs old.
Authorized Pest
Mike, That's awful what happened to you. However, except the split head ... great story and great find.
Peggy M I distinctly remember forgetting that.
