Sure, you know how to work on old trucks. Or maybe you're just starting in the hobby. Either way, safety is best learned through OPM (Other Peoples' Mistakes), not OJT!
Either as newly discovered wisdom, or a refresher, please read this article and live safely with your old truck!
I saw this truck at a local car show this past weekend. I the owner was not around at the time to ask about the truck but it is local and I hope to catch up with him later. The '58 appears to be mostly stock, it did have the fuel tank moved to the rear, other than that it seemed stock. The hood wasn't open but from under I could see it was an in-line 6 with a 3 speed column shift.
Craig
Come, Bleed or Blister something has got to give!!! '59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
Do you think that's "Polar Green" offered in 1958? Had to look twice but it looks very similar to "Galway Green" in 1959 (which I'm leaning toward using on my 59)
I have a '58 Apache 3100 that (I believe) was originally painted Glade Green (#705?). Its turqouise to my eye. I bought it in '89 and it was red then. If I ever have it painted again might change it back.
"What ARE you doing in the garage all the time" 58 Chevy Apache 3100 Stepside
