Safety First -- Tech Tip Highlight
Don't press your luck!
Sure, you know how to work on old trucks. Or maybe you're just starting in the hobby. Either way, safety is best learned through OPM (Other Peoples' Mistakes), not OJT!
Either as newly discovered wisdom, or a refresher, please read this article and live safely with your old truck!
A SHOP SAFETY Tech Tip
Searching the Site
2023 Old Truck Calendars
First one
Nothing like old trucks working
2023 Stovebolt Calendars
Check for details!
10 members (Brian Wise, Dragsix, fattboyzz, keithfielder, Hotrod Lincoln, 1 invisible), 93 guests, and 3 robots.
Forums60
Topics128,763
Posts1,059,621
Members46,752
Most Online1,229
Jan 21st, 2020
#1484897 Tue Jan 24 2023 05:16 PM
tamela Offline OP
Moderated
My Dad had a bunch of parts in his 1937 Ford that he had collected, and one of them was the visor in the pictures. Can anyone help me identify what is it that I have here? Some helpful person had posted all of the assembly manuals for Fulton Sun Shields in one of the forums, but I can't find anything stamped "Fulton" on the parts that I have. I have the hardware as shown in the photo, but nothing that would attach the visor to the vehicle. Can anyone tell me if this is a Fulton, what model it may be? I appreciate your help. Thank you.
tamela #1484946 Tue Jan 24 2023 10:58 PM
From what I have read about sun visors, it could be a Dieterich Standard. Is it steel or aluminum?
1947.2 Chevy Panel Truck 1 ton
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
tamela #1485021 Wed Jan 25 2023 01:57 PM
tamela Offline OP
Moderated
It is aluminum. Were both Fulton and Dieterich manufactured from aluminum?
tamela #1485065 Wed Jan 25 2023 07:26 PM
I read somewhere that Dieterich made steel visors and Fulton made aluminum. There were a dozen companies making visors, so your guess is as good as mine.
tamela #1485077 Wed Jan 25 2023 08:01 PM
tamela Offline OP
Moderated
Thank you, Walter!
tamela #1489671 Sun Feb 26 2023 01:48 PM
Dieterich visors were steel. They produced this visor pictured in 1953 only for the AD trucks. I fully reconditioned this one and installed it on my '48 Chevy 1/2 ton truck.
fonz8261 #1490482 Fri Mar 03 2023 07:02 PM
Fonz8261, I had to look at your links. I like your truck and all the doo-dads. I have a similar visor that I think is Dieterich. The center bar has the embossed ridge, the two halves are connected with Three bolts, unlike the Four bolts on yours, and the ends have Three holes where yours shows Two. How do you know your visor is Dieterich? Where did you get the end brackets?
walterhvogel #1490504 Fri Mar 03 2023 10:47 PM
The end brackets for my visor were included with the visor when I bought it. I replaced the old nuts/bolts, washers, etc. I bought my visor after careful research on the 1953 Dieterich AD truck visor well in advance of tracking mine down, and thoroughly examining what was being offered and had multiple conversations with the seller. They are hard to find.
Moderated by  klhansen, ndkid275, Rusty Rod
