Safety First -- Tech Tip Highlight
Don't press your luck!
Sure, you know how to work on old trucks. Or maybe you're just starting in the hobby. Either way, safety is best learned through OPM (Other Peoples' Mistakes), not OJT!
Either as newly discovered wisdom, or a refresher, please read this article and live safely with your old truck!
A SHOP SAFETY Tech Tip
Searching the Site
2023 Old Truck Calendars
First one
Nothing like old trucks working
2023 Stovebolt Calendars
Check for details!
9 members (Achipmunk, lumbersawyer, kahoys, booger, 66flea, 1 invisible), 98 guests, and 3 robots.
Forums60
Topics128,763
Posts1,059,616
Members46,752
Most Online1,229
Jan 21st, 2020
#1484925 Tue Jan 24 2023 09:06 PM
Is there a source for parking brake cables for a long bed? I see them for half ton, and it looks like 3/4 they use the same cable but put an extension on. I guess that would work, but it would be a long extension for a one ton.
2MANYTRUCKS, Good job. We thank you.
I think you found it! Thank you!
