Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
17 members (Gdads51, baldeagle, 32vsnake, 68ironhead, Flatblu4748, 3100Cummins, 1 invisible), 142 guests, and 3 robots.
The Zone
Forums65
Topics123,445
Posts999,543
Members47,279
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1484587 Sun Jan 22 2023 02:11 PM
Has anyone tried making an adapter plate to go from 7.25” 10 bolt to 11” 10 bolt to use modern 22.5” wheels? I’ve got adapters to convert the center hole, but just thought of this idea. I’ve seen adapter plates to change the number of bolts to adapt different wheels, I can’t see why this wouldn’t work.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
oldieoldie #1484588 Sun Jan 22 2023 02:21 PM
One can get 10 on 8.750”, 22.5” wheels(60’s GMtrucks) which can be found, and redrill them to 10 on 7.25” plus center hole adapters. Left hand wheel in picture. Milling machine and rotary table required.
Ed
oldieoldie #1486264 Fri Feb 03 2023 07:46 PM
I have adapters for the hub. What kind of tools would a shop need to be able drill the holes accurately?
oldieoldie #1486326 Fri Feb 03 2023 11:55 PM
Milling machine and rotary table. If they don’t know what you are talking about, go somewhere else! Find a proper ‘torque plate’ to finish the job! Drill the holes slightly under size, then use a 1/64” oversized reamer to finish holes, since two flute drills do not drill a round hole.
Ed
EdPruss #1493384 Wed Mar 22 2023 05:42 PM
Ed
Ed you have a picture of the finished product on the truck?
1946 Chevy Dually
oldieoldie #1493406 Wed Mar 22 2023 09:10 PM
Before sandblast and powder coat, trial fitting with hub adapter.
Ed
oldieoldie #1494956 Sun Apr 02 2023 05:07 PM
I found a shop who says they do the remake of the rim all the time. But they cut the center out and replace it with the center from the right bolt pattern.
oldieoldie #1494970 Sun Apr 02 2023 08:00 PM
Thanks, Ed- - - -you just saved me some money on a project I'm starting. I've got a 10 lug small bolt pattern vacuum shift 2 speed axle, and some 10 lug 24.5" wheels off a road trailer. I'm building a doodlebug tractor with a Turbo 350, a crash box 4 speed, and that rear axle, powered by a Mercruiser 4 cylinder engine. I was considering using Farmall Cub rear wheels adapted to the rear end, but lug tread 18 wheeler tires will work just as well- - - -especially if I run tractor inner tubes and fill them with liquid. I could even run dual wheels if I wanted to.
oldieoldie #1495023 Mon Apr 03 2023 01:52 AM
Big Bolt Forum Moderator
where did you get the adapters for the center hole?
Mike
1955 Chevy 6400 ex-flatbed (no bed now!)
In the Stovebolt Gallery [stovebolt.com]
Lincoln do they call you the mad scientist everytime to walk into the parts store or your metal supply I would love to see pictures of that when its done haha
1967 Chevy c50 327 w/ sm465 5000Ib front 15k 2 speed rear w/ 22k springs, single axle, hydraulic brakes
Page 1 of 2 1 2
