Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
2 members (klhansen, baldeagle), 46 guests, and 3 robots.
The Zone
Forums65
Topics123,445
Posts999,565
Members47,279
Most Online1,229
Jan 21st, 2020
Page 4 of 6 1 2 3 4 5 6
Fox Offline
In the Stovebolt Gallery [stovebolt.com]
More pictures here [photos.app.goo.gl]
1951 GMC 9430 1 ton dually—-Shiny!
1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny
1972 Chevrolet C20- Rusty- the puzzle box lid for the C10.
1950 Chevrolet 1300- in progress to shiny.
1962 AMC Rambler American- my wife’s
Parts trucks-
1951 GMC 9300
1951-GMC 9430
1951- Chevrolet 1300
MNSmith Offline OP
Originally Posted by Fibonachu
Edit: Looking closer those are injectors.
What electronics are you going to use to control it?
Edit Deux: Is this the 302 you mentioned in your other post?
Yes, they are injectors.
Today I was looking at the MS3Pro. It looks rather friendly, but I'm undecided at the moment. I'm still working on getting all the mechanicals in order, verifying firing order by cam, mostly just seeing what I got! I kinda don't want to disassemble anything, but I'd love to see if the roller cam has any markings. I'm short some push rods and need to plumb the rockers through the head. I also need to plumb the remote filter. I need to make sure that everything that is supposed to get oil, does. Kinda reverse engineer what's been done to this thing.
You know, the never ending "to do" list.
This is the 302 that I was figuring out what I needed for a bellhousing in my other post. I might have that part a little figured out. Still working on it.
The MS3Pro appears to have a good set of features on paper, but I have never been impressed with any of the megasquirt products I have used.
Have you looked at the Haltech units? Depending on what features you want, it might be a better option for you.
Do you know what you want to do for ignition? The Haltech supports drive-by-wire where the MS3Pro doesn't, but with what you have there going cable throttle probably makes more sense.
The Haltech can control a 4L60e and a few other transmissions if you decide on a modern automatic. The Haltech also supports closed loop automatic tuning. Whether that is a bonus or not depends on you.
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Apache, long bed Fleetside, V8 w/SM420
Driveable but the rear axle needs work.
1959 Apache, long bed Fleetside that has been in the family for 25 years but in desperate need of love.
She's screaming for a man pedal. Do you have flow numbers?
MNSmith Offline OP
I'll look in to it. I'm still a ways away from having to make a decision.
I'm not sure how a modern automatic would be possible. Mounting configurations for this block are limited.
MNSmith Offline OP
I do not. If there were any, I haven't found any on paper as such. Knowing the owner/builder, they were in his head and are now lost to time.
I saw your post in the youtube thread about sensors, but it seems more applicable to this thread so I will comment here.
You asked about measuring airflow on this engine. You would really need some kind of MAF per cylinder to do that. I will see if I can find a small one that would fit, but it would take some custom work.
I suspect that you are going to have to run this in speed density mode though. Not knowing the cam specs will make tuning that harder, but it is doable.
Depending on the ECU you go with, you will probably need MAP (manifold air pressure) and IAT (intake air temperature) sensors.
MNSmith Offline OP
Curious how that would work with 6 separate manifolds.
You could theoretically measure the airflow on each of them individually and fuel apprpriately, but I don't see any controllers that support that.
Edit: do you have any vacuum ports in that setup? I don't see any in the pics, but I am not sure everything is visible.
MNSmith Offline OP
None. Zero.
