Was the plate steel just welded to the angle strips? If so, it should be fairly easy to remove the angle strips. They were originally spot welded to the bed sides. On the outer side of the bed, run a sander along where the bed strips are (on the inside), then look for small dimples, which would be the spot weld locations. Then take a spot weld cutter
Link [
amazon.com] and drill them out and the angle strips should come off (you might have to pry a bit if your cutter doesn't remove all of the weld.)
If the plate steel was welded to the bedsides as well, you'll have to grind the weld off.
Hopefully they didn't do that.
Since this is your first post here, Welcome to the Stovebolt Forums.
Take a few minutes and head over to the
Welcome Centre and tell us a bit about your truck and yourself, and how you came about to own it. Also, post some pictures (instructions on the left of the page) - we love to see pictures.
Also you can click on your username at the upper right and click "Edit Profile" on the pulldown to put info about your truck in a signature (helps people know what you're posting about).
