New truck forum
New Forum Added in Parking Lot
EARLY BOLTS
1916 - 1936
1928 Chevrolet AB Canopy Express
"Justin"
Discussing issues specific to the pre-1937 trucks.
Searching the Site
2023 Old Truck Calendars
Second one
Sweet-looking old Stovebolts
2023 Stovebolt Calendars
Check for details!
14 members (fattboyzz, Dusty53, 1947_Big_Un, 5 invisible), 192 guests, and 3 robots.
Forums64
Topics122,540
Posts988,895
Members46,955
Most Online1,229
Jan 21st, 2020
#1483408 Sat Jan 14 2023 11:37 AM
Luray Offline OP
Hello, got some pine boards for 53 truck bed, what are other alternatives to use other than bed strips?
Luray #1483409 Sat Jan 14 2023 12:24 PM
Laminate it like a butcher block and install it in one piece?
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
Luray #1483445 Sat Jan 14 2023 06:45 PM
I have been looking at these as a potential option:
https://www.novausawood.com/hidden-deck-fasteners
From the Rocky Mountains?
Check in with the RM Bolters!
HiPo Forum Moderator
1958 Apache, long bed Fleetside, V8 w/SM420
Driveable but the rear axle needs work.
Fibonachu #1483451 Sat Jan 14 2023 07:57 PM
Installing a single piece in a '53 bed would be a trick. You'd have to remove the front panel and slide the single piece in below the angle strips and then reinstall the front panel and cross sill. Expansion and contraction of the wood would be an issue.
Those might work, but you wouldn't be able to carry any sand in the bed. Unless your objective would be to spread that sand along the road. It would leak thru the cracks. wink
Mar-K has different options for the bed strips, including hidden fasteners. If you're looking to eliminate the bed strips altogether, you could fasten them with wood screws through the cross-sills from below, but you'd need some provision to allow the wood to expand and contract. It would likely expand and buckle or contract and crack. GM had a pretty good design for the wood installation in the first place. Many wood beds have lasted 60+ years.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Luray #1483485 Sat Jan 14 2023 10:41 PM
When I haul sand, I generally throw a tarp down first to make it easier to clean out.
The bigger downside to the hidden fasteners (in my opinion) is that the bed strips give you something to slide pallets and such on without scraping up the wood.
Fibonachu #1483527 Sun Jan 15 2023 03:09 AM
yes
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
