Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
13 members (COCOE, Bill Hanlon, festerhairball, 32vsnake, 55shaker, Dusty53, 2 invisible), 110 guests, and 3 robots.
The Zone
Forums65
Topics123,394
Posts998,887
Members47,253
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1483223 Fri Jan 13 2023 12:01 PM
Hi Everyone!
I have a question of the day , I am trying to put new door panels on my 1952 Chevy 3100 and the old ones were just have panel over the top half covering the door handle and crank handle, i recently purchased an ABS door panel and want to get it upholstered with vinyl but when I screw the ABS door panel to the door it hits the door relay and it bulges out. As most of you know this relay protrudes out of the door by 3/8- 1#2 inch . Any ideas how to upholster this type of panel. I figure i can cut out the ABS to clear the relay but how to upholster this toi clear that relay.
Any photo will help
The Shop Teacher #1483232 Fri Jan 13 2023 01:42 PM
AD Addict
You have discovered the same issue most ‘AD ‘bolters run across. The bar when originally designed in 47, ran nicely in the channel below the handle, with the handle facing up, so the bar didn’t interfere with the interior door panel. You would open the door by pushing forward on the handle. In ‘49 they changed the direction the handle faced. One of GM engineers quick fixes. I suppose handles that opened on the forward position resulted in doors opening in crashes, are not such a good idea. They installed foam blocks to push the cardboard panel away from the inner door to allow more clearance for the bar. Much cheaper than changing the design of the inner door sheet metal to accommodate the bar in the upper position. It does cause the cardboard insert to bulge out a bit, but I suppose in a truck, that was acceptable.
I struggled with that same issue, seeing the nice depressed area where the bar sits so nicely, I tried to get it to fit but with no success. Unfortunately, I don’t have the answer and searched for answers, both in this forum and on the web without a suitable resolution. The only straight forward way is see is to change out the regulators to electric. Costly and not original. At least you know what the issue really is.
Maybe some other ‘bolters have other ideas they can share.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
Updated to: 12v w/alternator, HEI & PCV
Phak1 #1483281 Fri Jan 13 2023 05:21 PM
It took a long time but I was able to find original relays for my two '48 trucks. It's satisfying to see how nicely they fit on the door, as originally designed. I kind of like my Chevy where the relays are exposed better than the covered relays in my "fancy" GMC.
The Shop Teacher #1483699 Mon Jan 16 2023 03:05 AM
Thanks Phil
That explains a lot and makes total sense I will see what my upholstery guy comes up with and post on here a solution for thsoe who are redoing their door panels
Paul
The Shop Teacher #1483713 Mon Jan 16 2023 05:19 AM
What I don't understand is why GM didn't change the stamping of the door panel in '51 when they went to the vent windows. The inner panel is slightly different where the division panel for the vent windows installs, and the window regulator changed, although the mounting bolts may be the same.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
The Shop Teacher #1483767 Mon Jan 16 2023 05:46 PM
One could just use a cut-off wheel on an angle grinder and cut a slot in the door to allow the later model pull-to-open bar to be out of the way.
The Shop Teacher #1483791 Mon Jan 16 2023 07:52 PM
AD Addict
That may weaken the door too much unless you welded in a channel to strengthen it.
Phil
1952 Chevrolet 3100
Project Journals
The Shop Teacher #1500202 Tue May 09 2023 03:19 PM
Guys I read on one of the forums where they put the right relay on the left and the left on the right, not sure if that would remedy the problem.
Garcia50 #1500276 Wed May 10 2023 01:18 AM
AD Addict
I tried that awhile back and didn’t seem to make much of a difference. Thinking about it now, if you did swap the relays, install them so the linkage rods run down the channels, then installed the handles facing up, I believe it may just work! You would still have to pull the handles back so it wouldn’t be a safety issue.
The only issues I can see is you may only be able to use two of the three screws to install but that should be sufficient and the handle facing up is not stock.
Phil
1952 Chevrolet 3100
Project Journals
The Shop Teacher #1500287 Wed May 10 2023 03:38 AM
I found a work around for the door control rod misalignment you might try. The YouTube video linked below recommends replacing the 47 to 54 door controls with ones from a 1964 to 1966 C10. Available from the usual vendors. (Classic Truck Parts # 18-831 and 18-832) These will put the mechanisms in the door channel and allow the door panel to fit better. The inner door handles still work in the correct direction.
47-54 Chevy Truck Doors Tech Tip #HotRodDad #techtip #chevy3100
1954 Chevy 1300 engine 235 (1959)
1955 (first series) Chevy 3100 engine 261 (1957)
1927 (other brand) Model T- engine 327 (1968)
Page 1 of 2 1 2
Moderated by  ndkid275, Phak1
