New truck forum
New Forum Added in Parking Lot
EARLY BOLTS
1916 - 1936
1928 Chevrolet AB Canopy Express
"Justin"
Discussing issues specific to the pre-1937 trucks.
Searching the Site
2023 Old Truck Calendars
Second one
Sweet-looking old Stovebolts
2023 Stovebolt Calendars
Check for details!
11 members (Guitplayer, 55shaker, Coleunruh, Johnny N, 56Chevy6400, 32vsnake), 197 guests, and 3 robots.
Forums64
Topics122,538
Posts988,874
Members46,955
Most Online1,229
Jan 21st, 2020
Page 3 of 4 1 2 3 4
Otto Skorzeny #1482855 Wed Jan 11 2023 12:18 AM
I suppose a bulkhead fitting would work. This is only theoretical right now. I don't have plans to do it since my rebuilt fuel pump and rebuilt carb are working fine right now. I'm just thinking about it as a possible future project.
Where does the computer controller go? How is that hooked up? Will the sniper work with a breaker point system?
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
Otto Skorzeny #1482863 Wed Jan 11 2023 01:29 AM
The display/controller goes in the cab. They supply a holder for it.
It will work with points.
Dan
35 CC Case
38 Chevy Pickup
51 3100 AD
58 3100 Apache Fleetside
Otto Skorzeny #1482865 Wed Jan 11 2023 01:35 AM
Sorry for asking so many questions. Here are some more.
Do I understand correctly that you set up the sniper unit at a "base" level and then, as you drive the vehicle, the computer learns how the engine runs and either adjusts itself to the conditions or tells you what changes need to be made?
I suppose that since it isn't connected to the dizzy as well, it only has to worry about fuel mixture and not engine timing/advance.
Does the original throttle linkage hook up to it in roughly the same way as the carburetor?
1979 Ford F-100
Otto Skorzeny #1482867 Wed Jan 11 2023 01:54 AM
Yes you do basic set up and it does learn and self adjust.
You can interface with the distributor if so choose. I didn’t do that on mine.
I had to make a new throttle linkage from the bell crank on the side of the block up to the throttle body. Not hard to do at all.
The two manuals that you can print off of Speedways website are really good and explain the system very well. I’ll see if I can send them to your email.
I hope you install it, I think you’ll like it.
Dan
35 CC Case
38 Chevy Pickup
51 3100 AD
Otto Skorzeny #1482868 Wed Jan 11 2023 01:58 AM
The more I read about it the more exciting it is. I have too many other things going on with other cars right now to start anything like this. The price is also prohibitive, especially since the truck technically belongs to someone else. It's really intriguing, though.
The Mustang may eventually get it. The truck actually runs really well with the rebuilt YF carb and pump.
The photo of your engine bay shows what looks like a fuel pump down on the driver side. Is that what it is? I thought the pumps had to be back by the tank.
1979 Ford F-100
Otto Skorzeny #1482869 Wed Jan 11 2023 02:06 AM
That’s an aftermarket spin on oil filter.
Dan
35 CC Case
38 Chevy Pickup
51 3100 AD
D B Cooper #1482871 Wed Jan 11 2023 02:37 AM
Thanks, Dan.
I just discovered that Craig has already emailed me the two manuals.
Now I have something to read before I go to bed!
Thanks Craig.
1979 Ford F-100
Hotrod Lincoln #1483023 Thu Jan 12 2023 09:03 AM
Slavishly sticking to something that says "bowtie" simply for the sake of brand loyalty doesn't make good nonsense- - -
IMHO Jeep 6-bangers have a ton of potential if you after power, reliability and available parts.
I'm quite happy with the 261 in my 41, but I guess if I had to do it all over again, I would look into Jeep.
Frank
D B Cooper #1483025 Thu Jan 12 2023 09:49 AM
If you’re OK with keeping the tank in the cab and you don’t mind the noise an external pump makes, then yes the in cab tank can be used.
A (very pragmatic) friend of mine kept the tank behind the seat, but run a line from the bottom to an other tank between the rails in the back.
The return line also goes to the filler neck of the original tank - external pump somewhere in the back on the rails close to the new tank.
Many ways to skin a cat, IMHO not a bad solution if you want to keep the original filler, and almost twice the fuel capacity now.
Frank
Otto Skorzeny #1483090 Thu Jan 12 2023 06:20 PM
I had a Volvo inline six from the early 1970's with a VERY rudimentary electronic port fuel injection system. I believe it was a Bosch K-Jetronic. It used an electric motor driven remote fuel pump mounted on the frame just ahead of the fuel tank that produced 50-something PSI of fuel pressure. With an adjustable pressure regulator and a return lie to the tank, it would probably solve the problem of how to pump gas on a stovebolt installation.
For instance:
www.ebay.com/itm/363747105311? [ebay.com]
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!"
Abraham Lincoln
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
Page 3 of 4 1 2 3 4
