STOVEBOLTING!
Ready to get the truck on the road?
The Side Lot has the places with some action!
From West to East, South to North ... into Canada, of course!
Some groups have posted events that cover your roaming area.
Check in for starters, and check back often. Might be missing something like this
or
some variety.
15 members (FarmFresh47, Gdads51, burgundybolt, Hanks custodian, 87GN, 69Cuda, 1 invisible),
110
robots. |
Key:
Admin,
Mod
Forums60
Topics128,794
Posts1,059,841
Members46,755
Most Online1,229 Jan 21st, 2020
OP
Holley makes a Sniper unit specifically for the Ford 170/200/250 inline six to replace the Autolite 1100 carburetor.
Does anyone make a "bolt on" fuel injection system for Chevy inline sixes? Would a Holley Sniper 1100 system work on a S16? Would there even be adapters that would accept a Ford pattern on the Chevy Intake?
Just wondering if anyone has built a fuel injected 216.
1939 Packard Standard Eight Coupe (The Phantom) 1950 Chevrolet 3100 (Ol' Roy) 1956 Cadillac Coupe de Ville (The Bismarck) 1966 Oldsmobile Toronado (The Purple Knif) 1966 Ford Mustang (Little Red) 1964 Ford Galaxie 500 coupe 1979 Ford F-100 1976 Ford F-150 (Big Red) 1995 Ford F-150 (Newt)
"Lipstick on a pig"! The primitive port shape and lack of any kind of way to improve it noticeably makes any attempt at fuel injecting a stovebolt engine a fool's mission. The only really effective injection system is sequential port injection, which requires a separate intake port and injector for each cylinder, something that's utterly impossible with the siamesed ports of all the stovebolt engines, including the 194/230/250/292 series. Shared exhaust ports further complicate the breathing situation. Jerry
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!" Abraham Lincoln Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
OP
Gotcha. I figured there had to be a reason nobody is doing it or talking about it.
I was thinking about it more for reliability over the many problems with carburetors and fuel pumps associated with these engines rather than a performance enhancement.
It is pretty neat to see the little Ford 200 six with a store bought fuel injection system.
Aren’t more sophisticated head$ available from Falconer? ‘62 on.
Ed
Anything is possible, with enough time money, and dedication to a lost cause. If I was going to spend a lot of time and money on an injected inline six engine, I'd start with a Ford 300, an AMC 258, a GM Atlas six, or maybe a Toyota Supra Turbo DOHC engine. Slavishly sticking to something that says "bowtie" simply for the sake of brand loyalty doesn't make good nonsense- - - - -unless you're getting well paid to spend the other guy's money. That's how I stayed involved in round track racing for a few decades- - - -working for guys who had deep pockets and the "Go fast- - - - -turn left" addiction. Jerry
Which makes me repeat the same question I've asked before: When are you going to abandon the tractor engines and jump onto the Atlas engines? A REAL performance inline six AND a Chevy. I have the specs for an exhaust cam that deletes the VVT and has been proven in off road rides. Also have several FREE Atlas engines for test platforms.
Evan
There’s at least one guy around here that made a Sniper work on a 235 with positive results so far. I don’t think it was a performance thing so much as a drivability thing.
I’m really surprised Holley hasn’t created a system with the one barrel GM pattern yet…given the size of that market. I’m not looking to do it, but I understand the reasons of those who do.
Funny Jerry mentions the AMC/ Jeep engine. I was just pondering last night, what it would take to make one of those look less obvious in a Chevy engine compartment. The goofy valve cover would give it away quickly.
They are as common as dirt, reliable, capable, and have tons of aftermarket support.
OP
There’s at leas one guy around here that made a Sniper work on a 235 with positive results so far. I don’t think it was a performance thing so much as a drivability thing.
I’m really surprised Holley hasn’t created a system with the one barrel GM pattern yet…given the size of that market. Yes, that's what my thinking was. The six cylinder Fords don't really gain any performance - maybe fuel economy improves - but you don't have the carburetor issues anymore. The Autolite 1100 is an excellent carburetor but "new" ones are all foreign made and, like the Chinese Rochester Bs, they are crap. The conversion requires an electric, in-tank pump with a built-in regulator. I wonder if the person you're talking about adapted the Autolite replacement or if he used one of Holley's other units.
He used the Autolite version with a custom adapter. The guy is from Nebraska but can’t remember his username. Scroll back a few pages in the HIPO thread and you will find it.
OP
Interesting. Just to satisfy my curiosity I'll do that. I just found it. His is a 235 but since the Holley unit can be used on a 170, 200, and 250 Ford, I imagine 216 and 235 fit right in the range. https://www.stovebolt.com/ubbthread...sniper-install-on-a-235.html#Post1450618
