Time to hit the roads!
STOVEBOLTING!
Ready to get the truck on the road?
The Side Lot has the places with some action! From West to East, South to North ... into Canada, of course!
Some groups have posted events that cover your roaming area.
Check in for starters, and check back often. Might be missing something like this or some variety.
Searching the Site
2023 Old Truck Calendars
First one
Nothing like old trucks working
2023 Stovebolt Calendars
Check for details!
10 members (cmayna, Gdads51, 2-Ton, Bill Trotter, Bob King, 1 invisible), 108 guests, and 3 robots.
Forums60
Topics128,793
Posts1,059,854
Members46,755
Most Online1,229
Jan 21st, 2020
Page 4 of 4 1 2 3 4
Otto Skorzeny #1483103 Thu Jan 12 2023 07:21 PM
Jerry, you should install EFI on that crazy new engine you're building.
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
Otto Skorzeny #1483117 Thu Jan 12 2023 08:45 PM
Maybe- - - - -if I can figure out how to aim individual injectors at the back of every intake valve without creating coolant leaks in the cylinder head. It might be possible to use three injectors, one in each intake port, and cycle them once every turn of the crankshaft. That would be more efficient than a single throttle body injector that just dumps fuel at random into a plenum under the throttle plate like a carburetor does, and lets it find its own way to whatever valve opens next. There would be less opportunity for the fuel to fall out of suspension and puddle on the bottom of the manifold runners that way.
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!"
Abraham Lincoln
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
Page 4 of 4 1 2 3 4
