BUSY BOLTERS
Are you one?
The Shop Area
Forums65
Topics123,442
Posts999,498
Members47,277
Most Online1,229 Jan 21st, 2020
OP
What size bit for the door hinges 1942 chevy?
My local Ace Hardware, NAPA, Walmart, and Home Depot have clutch head bits (in stock).
OP
Bought a set of 4 from amazon largest 1/4 inch. Still to small for door hinge bolts.
Gearhead, Moderator for The Swap Meet and General Truck Talk
You need the 5/16" size clutch head bit if I recall correctly.
That size can be purchased separately from a number of our usual vendors.
Dan
1951 Chevy 3 window 3100 (My Grandpa's hunting truck) 1966 Chevelle (Wife's Hot Rod) 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) Com Fac Maint Lead Tech Retired (1998-2021)
Finally time to get to work on my Grandpa's (now mine) truck!
OP
That size can be purchased separately from a number of our usual vendors. Thank you I have one on the way.
Most Welcome
Dan
This set of 1/4 hex-drive bits arrived from Amazon today. PICQUIC 95010 Clutch Set 3/32, 5/32, 3/16, 1/4" $9.95 including two-day free shipping.
Wally
wallyp, Head Mechanic for Lynn's '53 3100Pickup
wallyp, Welcome to the Stovebolt. If you haven't already, feel free to go to the Welcome Forum and introduce yourself. Tell us a little bit about your projects there.
When it comes to 'clutch bit size', I generally go by, 'About yay size', or 'nope the bigger one', or 'I'm gonna need the drill on that one.'
