Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
2 members (baldeagle, Tommy631), 44 guests, and 4 robots.
The Zone
Forums65
Topics123,445
Posts999,567
Members47,279
Most Online1,229
Jan 21st, 2020
Page 1 of 4 1 2 3 4
#1481767 Wed Jan 04 2023 10:31 PM
MattMcK Offline OP
I am currently working on my 2 1/2 ton chevys brakes trying to get them to stop leaking. They are FR-3 type brakes and one of the brass blocks that splits the line between the two wheel cylinders on the passenger side is cracked. Does anyone know of a place I could get a new one? I havnt been able to find one online and most of the trucks at the junkyard were air brakes.
Is there a trick to making the tapered dowels not stick in the axle flange for next time I have to get to the brakes? I had a hard time getting one of the studs back in and im not sure its coming back out.
59 chevy Spartan 100, former firetruck
348ci with spicer 5 speed and electric rear
MattMcK #1481777 Wed Jan 04 2023 11:14 PM
MattMck,
Is your wheel bolt pattern 6 on 8.750 or 5/10 on 7.250? Is that broken block in the rear or front?
Ed
MattMcK #1481821 Thu Jan 05 2023 10:40 AM
MattMcK Offline OP
They are cast wheels so i guess that would be 5 on 7.250? Its the block in the rear.
MattMcK #1481824 Thu Jan 05 2023 11:48 AM
Do you mean Daytons?
Ed
MattMcK #1481902 Thu Jan 05 2023 08:10 PM
MattMcK Offline OP
Yes, they are Daytons.
MattMcK #1481967 Fri Jan 06 2023 12:40 AM
Mike Boteler
1956 Chevy 3100 Resto Rod [stovebolt.com]
1956 8400 Wrecker w/Holmes 525 [stovebolt.com]
1956 9200 Tractor w/Allison Automatic [stovebolt.com]
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 CJ-5 Navy Jeep
Hughesville, MD
MattMcK #1481977 Fri Jan 06 2023 01:05 AM
MattMcK Offline OP
Almost, but the one i need has two ports as well as the big hole which are at 90deg to each other.
MattMcK #1481979 Fri Jan 06 2023 01:19 AM
Can you post a picture of exactly where this fitting is located on your truck. Is it on the front or rear axle?
Mike B smile
Mike Boteler
1978 CJ-5 Navy Jeep
Hughesville, MD
MattMcK #1481984 Fri Jan 06 2023 01:43 AM
Mike Boteler
1978 CJ-5 Navy Jeep
Hughesville, MD
MattMcK #1482087 Fri Jan 06 2023 07:59 PM
MattMcK Offline OP
It is the rear axle. That might work, but i think it would be tight around the bleeder valve. That or i would have to route the brake lines different. The old one is like that one but 90 deg between the ports. $70 is a lot for that little thing too eek
Page 1 of 4 1 2 3 4
