Time to hit the roads!
STOVEBOLTING!
Ready to get the truck on the road?
The Side Lot has the places with some action! From West to East, South to North ... into Canada, of course!
Some groups have posted events that cover your roaming area.
Check in for starters, and check back often. Might be missing something like this or some variety.
Searching the Site
2023 Old Truck Calendars
First one
Nothing like old trucks working
2023 Stovebolt Calendars
Check for details!
18 members (87GN, FAST55, 1946chevypickup, 32vsnake, FarmFresh47, Chris Fingar, 1 invisible), 98 guests, and 3 robots.
Forums60
Topics128,793
Posts1,059,854
Members46,755
Most Online1,229
Jan 21st, 2020
Page 2 of 2 1 2
Getting silver solder to stick to stainless steel and cast iron at the same time is difficult, if not impossible. Brass would be much simpler to get a water-tight bond. Of course, green LocTite "stud and bearing mount" along with a snug press fit would probably work as well as silver solder, and be easier to apply. It's stable up to 500+ degrees F.- - -far hotter than a sleeve exposed to coolant would ever get.
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!"
Abraham Lincoln
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self.
Ernest Hemingway
Learned something on the interwebs last night. Ended up on the website of a custom rocker manufacturer specializing in shaft mounted rockers. You can order roller rockers in all kinds of lengths, ratios, and (L/R) offset.
I’m sure they cost a bloody fortune, but looked to me like a guy could build a custom Stovebolt rocker set if he wanted.
I didn’t know “custom rockers” were a thing.
Have you guys seen this?
Posted by Guadalupe Manuel Torres on Facbook - 848 head for use on a 261.
I'm getting pretty close to getting my 216 head assembled- - - -just a bit more fabrication involved. Fortunately, the only "custom" parts involved will be the mounting plates for the rocker studs, and special length pushrods. The roller rockers and studs will be off the shelf big block V8 high performance items. I might be able to modify regular stovebolt pushrods if I choose not to use the roller valve lifters on the bottom end. I've figured out how to make a 261/Corvette cam fit a 216 block by machining the bearing journals for the smaller 216 cam bearings.
Abraham Lincoln
Ernest Hemingway
W/r/t custom shaft-mount rockers
It's not the machining, which is obvious - begin with an aluminum plate.
The hard part: with no other information, what are the relationships between the stems and rocker construction?
For those not familiar: no rocker arm is a "see-saw" with the ends horizontal and the fulcrum dividing the arm lengths to get the right ratio.
OK- - - - -here's a quick update:
I got the rocker studs mounted to a junk 216 head today, and started doing some preliminary fitting of the rocker arm to valve geometry. I'll be using a lash cap to widen the footprint at the top of the valve stem, and an adjustable pushrod to determine the best angle of the rocker to the valve stem- - - - looking for a 90 degree angle between the rocker tip and the valve halfway up the cam lobe. Obviously, that will need to be finalized once a complete valve train is mocked up- - - -cam, engine block, cylinder head, head gasket, etc.
Pushrod angles will be somewhat of a sticking point, especially if the same setup is applied to a 1954-up 235 with a different water jacket. I'll cross that bridge once I have a running 216 and/or spray oiler 235 in operation and some dyno testing documented.
Pics:
Abraham Lincoln
Ernest Hemingway
Dang, Jerry! I sure am happy to see you actually getting into building one of your pipe dreams, given your seemingly endless calamities in recent times. Very good to see! I am inspired. Makes me realize that I do indeed have at least a few good years left ahead of me. smile
Like Clint Eastwood says- - - - -"Don't let the old man in!" I just wish someone a few years younger (or maybe a LOT younger) would show some interest in carrying on the tradition of trying to do the "impossible"! So far, no takers, including my son and grandson!
Abraham Lincoln
Ernest Hemingway
Ingrates!
I wish you were my Granddad. I'd be at the shop every day.
1939 Packard Standard Eight Coupe (The Phantom)
1950 Chevrolet 3100 (Ol' Roy)
1956 Cadillac Coupe de Ville (The Bismarck)
1966 Oldsmobile Toronado (The Purple Knif)
1966 Ford Mustang (Little Red)
1964 Ford Galaxie 500 coupe
1979 Ford F-100
1976 Ford F-150 (Big Red)
1995 Ford F-150 (Newt)
Don't sell yourself so short. I'm sure you have inspired many, many on this site over the years to try high end, hairy projects.
Page 2 of 2 1 2
