Corona Sam,
First off, glad to see you back.
Your posts have been kinda few and far between, but no problems at all.
Just a note that you are still in "Moderated" status and need to complete at least 1 more post to get to full 'Bolter status (can then use all the functions like PMs to other members, etc.).
Before you get too much farther in your process, you might consider taking a look at this ad (not mine)
from "Mator58" in the Swap Meet Truck Parts for Sale forum.
One of the things he is offering (and pictures are there) is a dual exhaust set up that he indicates was connected to a set of Fenton exhaust manifolds coming from his 235 equipped '58 Task Force truck. Would/could provide some info in answer to what you are asking.
Up to you if maybe of interest to you or not.
Others that have some experience with what you are asking about will mostly likely chime in here soon as well.
Good luck in your search!
