STOVEBOLTING!
Ready to get the truck on the road?
The Side Lot has the places with some action!
From West to East, South to North ... into Canada, of course!
Some groups have posted events that cover your roaming area.
Check in for starters, and check back often. Might be missing something like this
or
some variety.
Forums60
Topics128,794
Posts1,059,841
Members46,755
Most Online1,229 Jan 21st, 2020
OP
Moderated
I have a 41 Chevy Ak with a camaro frame. Previous owner laid wood 2x4's and a sheet of plywood with a rubber mat on top of that for the bed. I want to remove all that. I ordered a bed kit but having a hard time configuring the cross sills. Does anyone have a diagram of the cross sills? Was told the rear cross sill goes in position #2 from rear of cab. Just looking for some guidance before the parts come in.
Kendall, Welcome to the Stovebolt forums. You should head over to the Welcome Centre and tell us a bit about yourself and your truck. If you ordered from Mar-K your wood kit will come with an instruction sheet. That will tell you where the cross sills go. Also the metal strips give you some clues as the bolts go through the cross sills.
Kevin Newest Project - 51 Chevy 3100 work truck. Photos [ flickr.com] #2 - '29 Ford pickup restored from the ground up. First car '29 Ford Special Coupe Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
“Grease Monkey” “Former herder of cats”
You can search Mar-K’s website for detailed drawings and instructions.
Martin '62 Chevy C-10 Stepside Shortbed (Restomod in progress) '47 Chevy 3100 5 Window (long term project) ‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily” ‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one! Support those brave men/women who stand the "Thin Blue Line"! Hug a cop! USAF 1965-1969 Weather Observation Tech (I got paid to look at the clouds)
