Time to hit the roads!
STOVEBOLTING!
Ready to get the truck on the road?
The Side Lot has the places with some action! From West to East, South to North ... into Canada, of course!
Some groups have posted events that cover your roaming area.
Check in for starters, and check back often. Might be missing something like this or some variety.
Searching the Site
2023 Old Truck Calendars
First one
Nothing like old trucks working
2023 Stovebolt Calendars
Check for details!
16 members (D B Cooper, 69Cuda, burgundybolt, Gdads51, 2 invisible), 96 guests, and 3 robots.
Forums60
Topics128,793
Posts1,059,845
Members46,755
Most Online1,229
Jan 21st, 2020
Page 1 of 2 1 2
#1477043 Thu Dec 01 2022 12:13 AM
37 GC Offline OP
Starting to consider putting my Carpentry skills back to work and get ready for the bed work. My '37 didn't have enough left for a sample so was the thickness a true 1" (5/4)? appears to be more than typical 3/4". I'm considering Brazilian Ironwood (IPE) had a deck out of the stuff and it was hard to work with but pretty amazing. Anyone used it?
Larry
All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
37 GC #1477058 Thu Dec 01 2022 01:58 AM
Not sure about the earlier trucks, but the 47-72 wood was 3/4" thick. I'd be surprised if the earlier trucks would be thicker. Here's a reference: Link [gmcpauls.com] Also, Mar-K would know for sure. Link [mar-k.com]
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
37 GC #1477080 Thu Dec 01 2022 12:26 PM
I am going with composite decking. You will need once more ss strip to make it work.
1966 C-10 Step Side. 283, 4spd, 3.73 gear. 60K miles prior to restoration. 507 Paint Code. Currently in 10,000 pieces, but it's starting to go back together.
Rear Suspension is done! Wheels are done! Bed bodywork is done! New 383 and TKO 5 speed in place.
37 GC #1477100 Thu Dec 01 2022 03:24 PM
Insomniac
I considered Ipe, Purple Heart and others. Probably would have used Ipe, but settled on Maple as the price was right and it was a local source. I wouldn't use a softwood.
It's a personal preference.
The link Kevin supplied shows dimensions for the boards. My neighbour has a nice wood shop and was pleased to help.
Gord
1954 1/2 ton 235 4 speed
37 GC #1477103 Thu Dec 01 2022 04:12 PM
Authorized Pest
Been asked to move this to Making a Stovebolt Bed.
smile
Peggy M
I distinctly remember forgetting that. grin
37 GC #1477125 Thu Dec 01 2022 06:33 PM
Authorized Pest
Lou MacMillan has asked me to post a response in here. May take me awhile to get it set up.
(Was great to hear from Lou! The 1937 Ambulance ... one of Lou's Tech Tips. 1937 1.5-Ton Chevy Ambulance - one of early Gallery submissions. (Before we started numbering them even!)
Stay tuned ...
Peggy M
37 GC #1477126 Thu Dec 01 2022 06:37 PM
Authorized Pest
From Lou:
Hi Bolter,
Most of the 37 Chevys in the Western US, used ash for bed wood. The ton & half Canopy (pictured) used 3/4" thick planks. The seven uneven widths, with routed depressions for ware irons, are held down off set washers and carriage bolts. (Pix #2)
The wood was originally painted black. Once painted black, it was too pretty to hide the grain so I sanded it and clear coated the surface.
The Panels and Canopies used the same wood. The Suburbans used plywood. I believe you can order wood "kits" for flat bed and open express from Carter's and Filling Station.
If you wish to contact me, my email is: c1937@znet.com
Lou
Peggy M
Gord&Fran #1477133 Thu Dec 01 2022 07:55 PM
Unfortunately, that link only has dimensions for 47 and later truck beds. The earlier trucks had a narrower bed, so the width dimensions in that link won't help. But I'm sure that Mar-K has that info and could share it (they may want a few bucks for a data sheet, as they're in the business of selling wood kits, which is understandable.)
Ferris Bueller #1477169 Fri Dec 02 2022 12:44 AM
37 GC Offline OP
Ferris, one more SS strip because the deck board width is less than original? I used marine ply cut into strips and routered in my ‘63 fleet side years ago, but of course I ripped it how I wanted. Deck boards are like 2x6 (5 1/2” wide)? I’ll have to break down and do some measurements and math. My bed is narrower than your AD also…
Larry
37 GC #1477369 Sat Dec 03 2022 09:48 AM
If you have the rear sill (cross member) then you have the board widths, just measure between the bolt holes in the rear cross member. Have used measurements from rusty, bent or mangled ones. If extra holes drilled by PO's one can tell the punched factory holes.
Evan
Page 1 of 2 1 2
