Forums59
Topics128,332
Posts1,054,206
Members46,615
Most Online1,229 Jan 21st, 2020
OP
I have recently bought a 51 GMC 350-24 that has a 302 in it… It has been parked for I’m assuming 50 years… - still has oil in it. - turns over easily (only moved a few degrees to avoid scratching cylinders but check for freedom of movement.
My plan is to: -pull the valve cover and hit all the rockers with penetrating oil - replace (if needed) condenser and set points -new coil -new plugs and wires - some light oil in each cylinder - change oil -pour oil into oil filter canister - remove water pump/fan/generator belt
Then I plan to Turn over by hand a few rotations, and if everything looks free give it some gas and see if it’ll run…
If she runs and sounds viable, I’ll rebuild the carb and see if it will run without being hand fed… and then throw the accessories back on and put coolant in once it’s closer to ready to try to move under its own power…
Any other suggestions?
Regarding the light oil in each cylinder, I suggest using a little automatic transmission oil and let it soak at least one day before trying to fire it up.
Besides lubricating the cylinder walls, the ATF will seep into the rings and help loosen them.
Set up your camera to video the start up attempt! The first time firing in over 30 years only happens once!
Fingers crossed, Dean
Give the lifters a soak too.
In the Stovebolt Gallery [ stovebolt.com] More pictures here [ photos.app.goo.gl] 1951 GMC 9430 1 ton dually—-Shiny! 1970 Chevrolet C10 - Grandpa’s- My first truck.—in progress to shiny 1972 Chevrolet C20- Rusty- the puzzle box lid for the C10. 1950 Chevrolet 1300- in progress to shiny. 1962 AMC Rambler American- my wife’s Parts trucks- 1951 GMC 9300 1951-GMC 9430 1951- Chevrolet 1300
DO NOT put gas into the onboard fuel tank. Use a remote tank like one for an outboard boat motor, etc. Fresh gas will dissolve all sorts of crud left over from decades-old gasoline, which will end up in the valve guides. The next time you try to start the engine, you'll probably bend a bunch of pushrods and/or rocker arms, or even hit the stuck valves with the pistons. It's a chronic problem on Chevy engines, and probably the same thing will happen on a GMC. Jerry
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!" Abraham Lincoln Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
The one thing I always do is turning the oil pump with a drill till I got oil at the rockers.
Frank
AD Addict
There is a Tech Tip for reviving a sleeping engine that has allot of good tips. Here is a [LINK].
-pour oil into oil filter canister Because this is a bypass filter you don't need to do this to get oil pressure to build quicker, but it will drop oil onto the distributor gear where it meshes with the camshaft.
Make sure to oil the valve stems frequently just before startup!
Ed
