Forums59
Topics128,332
Posts1,054,207
Members46,615
Most Online1,229 Jan 21st, 2020
Waveski Sounds like you are fixed up on heater fan cotrols,you'll need em in sheboygen ! I cobble together resistors and use a 6v motor your 12 volt system is best by far.
OP
Hopefully fixed up soon , but not yet. Too cold to work in my unheated garage this morning - 12 degrees f. !!!
Age 68 is not too late to start hot rodding , right?
You need a salamander heater.
1939 Packard Standard Eight Coupe (The Phantom) 1950 Chevrolet 3100 (Ol' Roy) 1956 Cadillac Coupe de Ville (The Bismarck) 1966 Oldsmobile Toronado (The Purple Knif) 1966 Ford Mustang (Little Red) 1964 Ford Galaxie 500 coupe 1979 Ford F-100 1976 Ford F-150 (Big Red) 1995 Ford F-150 (Newt)
OP
Actually , I need to button up the minor projects in progress and store my truck for the winter. Didn’t start driving it till mid September , so I’ve been holding out.
Waveski Use the simple rheostat,that standard is liable to be an offshore unit though,I still use a 6 volt motor with NAPA resistors I guess because itis still alive. Have 2 speeds in the original switch but always use hi it's not objectionably noisy though. The NAPA system works but is kind of expensive and is more riggin' under the dash.
Yes, the Standard unit is made in China. It's virtually identical to the original switch I removed. I even weighed both of them and they're identical. (I often weigh "identical" parts and find that the new Chinese ones are lighter due to shaved dimensions, etc).
The noise on high is no louder than the fans on any of my other vehicles except the Cadillac. And in the AD truck it will be covered up by wind noise and valve clatter!
OP
My single speed fan is quite loud. I will give the control I received, probably Monday/ Tuesday after returning from holiday travel.
The noise on high is no louder than the fans on any of my other vehicles except the Cadillac. And in the AD truck it will be covered up by wind noise and valve clatter! Otto Scorzeny LOL You 've got that right wind noise and valve clatter !!
OP
Valve clatter I don’t have- 283. Lots of road noise though, no sound treatment yet. No headliner either.
Update/ non-update: My 3100 went into winter storage earlier this week , one step ahead of the street salt applicators. Switch installation not yet done. Thread probably is.
