Holidays are over
Hunkering down for winter ... how about your truck?
Forums59
Topics128,266
Posts1,053,232
Members46,580
Most Online1,229 Jan 21st, 2020
OP
Got a 12 cylinder Jaguar in for wiring up an LS conversion. Quoted 4k and then another 1k to move to trunk after it was a running ride. Was worth more. Seems computers are resistant sensitive so spent a week finding wires with low resistance which turned out to be elevator wires from a 50 story building. Very fine and pure copper. Should know better than to touch anything that was Lucas Electric from the factory.
Evan
Back in the dark ages there was a company that specialized in producing adapter kits for installing Chevy engines in Jags. It was called "J.T.R." ("Jags That Run") If memory serves me correctly, there was even a setup to put a big block engine in a Jag frame! Jerry
"It is better to be silent and be thought a fool than to speak and eliminate all doubt!" Abraham Lincoln Cringe and wail in fear, Eloi- - - - -we Morlocks are on the hunt!
There is nothing noble in being superior to your fellow man; true nobility is being superior to your former self. Ernest Hemingway
I believe that's who I got the VSS sensor from for my Burb.
Should know better than to touch anything that was Lucas Electric from the factory. Wasn't their slogan : Lucas Electric, home by dark!
BC 1960 Chevy C10 driver 261 T5 3.73 dana 44 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022
Crusty Old Sarge
Back in the dark ages there was a company that specialized in producing adapter kits for installing Chevy engines in Jags. It was called "J.T.R." ("Jags That Run") If memory serves me correctly, there was even a setup to put a big block engine in a Jag frame! Jerry The shop I worked at in Highschool specialized in SBC conversions in Jay's. We would do a couple a month, seems it was easier to make the change than do the maintenance on the Jag.
Craig
Come, Bleed or Blister something has got to give!!! '59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting)
OP
Craig, We used to do a lot of Jag to SBC Chevy swaps and the best comment we ever got was a customer said that with the Jag engine gone his driveway was getting rusty from lack of oil.
Evan
Anybody ever tried to do a valve adjustment on a DOHC Jag inline six after a valve regrind? There was an assortment of different thickness buttons that fit between the cam followers and the valve stems. Once the valves were all adjusted and the cams bolted back into place, then setting the cam timing was the next challenge! Not a job for an impatient mechanic! Jerry
Not a Jaguar but I did do a similar job on our 1975 Fiat 124 Spyder with it’s DOC4. Just before a long weekend drive through the Ozarks In the late 70’s I decided to change the dual points and plugs just because. Car was actually running fine. The little dual overhead cam engine had round spacers that determined valve lash.
When changing the points I discovered a screw hole was stripped in the point plate. No problem, I found a slightly larger screw in the toolbox, problem solved.
Finished the tuneup and it wouldn’t start. The battery was a little weak so I rolled it down the long steep driveway.
Short story long. It didn’t start. The slightly larger screw was a bit longer, locked the distributor up when it hit the counterweights. This locked the exhaust cam up. The timing belt jumped time. Pistons hit valves bending a few.
We didn’t cruise the mountains that weekend.
After pulling the head and having repairs made, I learned about setting valve clearances. After bolting the head back on with the original shims, checked and recorded clearances. Drove to Roy Rogers Foreign Car parts in Little Rock with my list and they provided the necessary new shims.
I still run across some of the original shims in a catchall box and they remind me of that lost weekend. We did make the trip a few weeks later and the car ran great!
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
Socket Breaker
Back in the dark ages there was a company that specialized in producing adapter kits for installing Chevy engines in Jags. It was called "J.T.R." ("Jags That Run") If memory serves me correctly, there was even a setup to put a big block engine in a Jag frame! Jerry They are still around HRL, https://jagsthatrun.com/They have the jag setups, s10, datsun z cars and volvo swap information and parts now.
